Hp 15 dau88mm6a0 bios
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: Hp 15
    This is original chip bkup no display.
    • smali
      • Sep 2014
      • 287
      • Pakistan
      Re: Hp 15
      your file is BID0233F and i uploaded the same BID as file name 0233FF25.
      • imranromi
        • Jan 2015
        • 1288
        • Pakistan
        Re: Hp 15
        the original bios data and u send 5 bios data when compare original and u send bios data many different no same.
        • smali
          • Sep 2014
          • 287
          • Pakistan
          Re: Hp 15
          I collect the updated version and your may be old version there for many deference.
          program the file 0233FF25 in the folder as i uploaded. if the same position then you have not bios problem. then reflow your PCH and graphics chip if on your PCB.
          • imranromi
            • Jan 2015
            • 1288
            • Pakistan
            Re: Hp 15 DAU88MMB6A0
            here is a working bios.
            HP 15 DAU88MMB6A0.
            • highpulse
              i hate HP
              • May 2013
              • 1488
              • portugal
              #26
              Re: Hp 15
              well i got mmy adapter and working with the TL866cs programmer , but still can read or write or detect the 64FW .. flashed with latest software for the mini pro , version 6.50 , it does show now on the search field the 64fw as all outher FW's , but when i select winbond 64w , can't read , detect or flash .. something doing wrong ?
              • highpulse
                i hate HP
                • May 2013
                • 1488
                • portugal
                #27
                Re: Hp 15
                this adapter not good for tl866 , the correct one should be the SN006_25_1.8V
                • Ahari
                  by Ahari
                  I...
                  Yesterday, 06:12 AM
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • haitham sharabati
                  [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                  by haitham sharabati
                  Hello engineers 😀,
                  I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                  🔧 Device Info:
                  - Model: HP 15-da2007ne
                  - Product Number: 8XF55EA#ABV
                  - Serial Number: CND0338P0D
                  - CPU: Intel Celeron N4000
                  - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                  💀 Problem:😅
                  - Device shows “Administrator Password”...
                  08-07-2025, 04:54 AM
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
                • DynaxSC
                  by DynaxSC
                  11-17-2023, 10:56 AM
