UX31A2 REV 4.1 bios dump
  • highpulse
    i hate HP
    • May 2013
    • 1489
    • portugal
    anyone with this dump available ?
    thk in advance
  • kotnatan
    Banned
    • Apr 2014
    • 181
    • Ukraine
    Re: UX31A2 REV 4.1 bios dump
    Try this
    ASUS UX31A2 REV 4.1 BIOS VER 215
    ASUS UX31A2 REV 4.1 BIOS VER 219
    • highpulse
      i hate HP
      • May 2013
      • 1489
      • portugal
      thk kotnatan , this machine is turning on , alltough there is no gfx core or vcc core for cpu , cheked rt8168b , enable pins are ok , vin , vccc etc all seem working normal , simply no power for gfx core and vcccore
      • highpulse
        i hate HP
        • May 2013
        • 1489
        • portugal
        also machine does turn on with F2(wlan) led on and caps lock led ON , machine have a overall consume of 0.22amp .
        • degutji
          • Dec 2012
          • 173
          • Indonesia
          Have you solved this ? Got this symptom also
          • javedharun
            • Feb 2016
            • 12
            • india
            la-c631p bios need clear me urgent
            both of
              • 20286
              both of
              Start a new thread, this post is about a UX31A2 REV 4.1 bios dump.
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
              • grimacelord
                Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                by grimacelord
                This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                Motherboard model number: DA0PAMB46A1 REV: A
                Secondary motherboard model number: 0PAB
                SKU: 685K4UA
                Serial number is: 5CD3223BJP
                Recently reflashed this laptop with latest BIOS and once...
                05-07-2024, 08:06 AM
              • DynaxSC
                Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                by DynaxSC
                I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                11-06-2022, 05:22 PM
              • vinaypundith
                Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                by vinaypundith
                I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                So, I'm looking for a BIOS dump for this machine - a 16MB one....
                08-03-2024, 12:32 PM
