Bios dump Sony Fit 15 (DA0GD6MB8E0 Rev E)
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Hello Friends
    I need a bios dump for a Fit 15 svf15a1c5e laptop
    Motherboard is DA0GD6MB8E0 Rev E
    Thank you
    Here my broken dump
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Re: Bios dump Sony Fit 15 (DA0GD6MB8E0 Rev E)
    Ok, Laptop is living again, i used a russian bios and when i press the "assist" key, i get the menu in russian, at least the bios is in English, lol !
    This was a nice investment, 60 euros for a full HD 15,6, Core I3, 8gb Ram and aluminium chassis, will keep this one for me
    here the bios that i used:
    • rookieme
      • Oct 2014
      • 397
      • Greece
      We can edit the working bios with data from the old so the menu will change language.
      • passete
        Living=Sharing
        • Jun 2015
        • 487
        • France
        I also lost the Windows 8 licence, tried to install win 8 oem and it's asking for a key.
        Can you also retreive the licence ?
        • nts28
          • Nov 2015
          • 33
          • türkey
          thankyou
          • ravenmx
            • May 2018
            • 171
            • puebla
            thanks works
            • patocodu
              • Sep 2014
              • 8
              • ecuador
              Excellemt tks
              • Slavol
                • May 2015
                • 72
                • Poland
                Yes - in this dump Sony Vaio Care is in RUS
                Here is dump with Vaio Care ENG... WK is XXXX
                • O.Szilard
                  • May 2019
                  • 161
                  • hungary
                  Thx!
                  • DynaxSC
                    by DynaxSC
                    11-17-2023, 10:56 AM
                  • grimacelord
                    Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                    by grimacelord
                    This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                    Motherboard model number: DA0PAMB46A1 REV: A
                    Secondary motherboard model number: 0PAB
                    SKU: 685K4UA
                    Serial number is: 5CD3223BJP
                    Recently reflashed this laptop with latest BIOS and once...
                    05-07-2024, 08:06 AM
                  • DynaxSC
                    Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                    by DynaxSC
                    I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                    It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                    I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                    11-06-2022, 05:22 PM
                  • vinaypundith
                    Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                    by vinaypundith
                    I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                    So, I'm looking for a BIOS dump for this machine - a 16MB one....
                    08-03-2024, 12:32 PM
                  • Buzzfuzz2k
                    Bios password removal on a Unowhy dump
                    by Buzzfuzz2k
                    Hi Everyone,
                    I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                    The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                    the Computer is a Unowhy small pc
                    N° UYM6524702229
                    After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                    My first attempt was to get the bios dump from windows...
                    11-13-2023, 07:37 AM
