need bios original file is this
toshiba L50-CR10FG-6050A2556410-mb-A02 bios
Re: toshiba L50-CR10FG-6050A2556410-mb-A02
can you download this file and post it here?
Code:http://fs3.pc.toshiba-asia.com/toshibasg/drivers/public/doc/SL50A_SPL50A_TC50150700E_WIN.exe
Im Back... sort of... -
since 6 month ago, i can't download bios from toshiba-asia, its seem link has down. the transfer rate not increase even 30 min have waiting for. maybe its not your problem, but i think toshiba-asia has problems.
http://support.toshiba.com/support/d...ext=1200007566
maybe this link workComment
i managed to download, but it goes so slow and sometimes stops
here is file, hope it helps
make backupAttached FilesIm Back... sort of...Comment
Here you go.Attached FilesLast edited by diif; 03-08-2016, 05:46 AM.Comment
by bondminer009Good Evening,
Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
Thank You
Salam,
Three-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by joshAUHi all.
I'm looking for a BIOS file for an Asus N550JK.
I have a Asus R552J, which I believe is identical to the Asus N550JK.
I downloaded the latest BIOS (210) for the R552.
It is named N550JKAS.210.
The BIOS file is however only 6mb in size.
I've read the chip with a CH341A programmer and verified the file.
That file is actually 8mb in size.
I'm wanting to remove the BIOS password from this unit.
It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...-
by adelageHi,
I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?-
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
- Loading...
