Need Bios Sony Fit 15E (DA0HK9MB6D0 REV.D) Dump available
  • kero_kerokk
    • Aug 2017
    • 14
    • egypt
    Re: Need Bios Sony Fit 15E (DA0HK9MB6D0 REV.D) Dump available
    • corneldeacu123
      • Aug 2016
      • Romania
      • zmedia
        • May 2018
        • 62
        • Algerie
        pleas help me i need bios DA0FI1MB8D0 Rev-D Sony Vaio Flip 13 SVF13N thnaks
        • ravenmx
          • May 2018
          • 165
          • puebla
          Originally posted by imranromi
          try this
          thanks you works
          • tmaciejs
            • Oct 2018
            • 11
            Thank you - all work
            • zedameo
              • Jan 2019
              • 14
              • algeria
              #26
              thank you, it worked
              • fikonaz
                • Mar 2017
                • 37
                • turkey
                #27
                thanks
                • Wilfried
                  • Sep 2019
                  • 81
                  • Cameroun
                  #28
                  Please i need help. My backup is 8193kb
                  with another 1kb file but the one you post is 8193kb and it doesn't fit into my chip. I can do how to fix this problem 🙏
                  • Wilfried
                    • Sep 2019
                    • 81
                    • Cameroun
                    #29
                    Please help me fix this file
                    • kayitsiz
                      • May 2017
                      • 18
                      • istanbul
                      #30
                      thanks
                      • djharold
                        • Aug 2015
                        • 241
                        • COLOMBIA
                        #31
                        Originally posted by ivanxxx
                        try this one
                        thanks
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11659
                          #32
                          Sony Fit 15E
                          • scorpion_3477
                            • Aug 2022
                            • türkiye
                            #33
                            Hello there. I need bios file for sony SVF1521NSTW DA0HK9MB6D0 REV.D please help.
                            • peste
                              • Dec 2016
                              • 12676
                              • ROMANIA
                              #34
                              make a copy of the original bios of the laptop and try post #2
                              • epoy
                                • Jun 2016
                                • 43
                                • phillipines
                                #35
                                thanks you!!!!!
                                • iga
                                  • Nov 2024
                                  • Туркменистан
                                  #36
                                  thank you guys, u r the best
                                  • Habble7
                                    by Habble7
                                    Suspected Cause:
                                    Troubleshooting Attempts:
                                    05-22-2025, 07:28 AM
                                  • DynaxSC
                                    by DynaxSC
                                    11-17-2023, 10:56 AM
                                  • grimacelord
                                    Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                    by grimacelord
                                    This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                    Motherboard model number: DA0PAMB46A1 REV: A
                                    Secondary motherboard model number: 0PAB
                                    SKU: 685K4UA
                                    Serial number is: 5CD3223BJP
                                    Recently reflashed this laptop with latest BIOS and once...
                                    05-07-2024, 08:06 AM
                                  • DynaxSC
                                    Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                                    by DynaxSC
                                    I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                                    It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                                    I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                                    11-06-2022, 05:22 PM
                                  • TacticalFahrrad
                                    [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                    by TacticalFahrrad
                                    I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                                    BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                                    I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                    06-30-2025, 04:09 AM
