Need Bios Sony Fit 15E (DA0HK9MB6D0 REV.D) Dump available
  • kero_kerokk
    • Aug 2017
    • 14
    • egypt
    Re: Need Bios Sony Fit 15E (DA0HK9MB6D0 REV.D) Dump available
    • corneldeacu123
      • Aug 2016
      • 3
      • Romania
      • zmedia
        • May 2018
        • 63
        • Algerie
        pleas help me i need bios DA0FI1MB8D0 Rev-D Sony Vaio Flip 13 SVF13N thnaks
        • ravenmx
          • May 2018
          • 180
          • puebla
          Originally posted by imranromi
          try this
          thanks you works
          • tmaciejs
            • Oct 2018
            • 11
            Thank you - all work
            • zedameo
              • Jan 2019
              • 14
              • algeria
              #26
              thank you, it worked
              • fikonaz
                • Mar 2017
                • 38
                • turkey
                #27
                thanks
                • Wilfried
                  • Sep 2019
                  • 81
                  • Cameroun
                  #28
                  Please i need help. My backup is 8193kb
                  with another 1kb file but the one you post is 8193kb and it doesn't fit into my chip. I can do how to fix this problem 🙏
                  • Wilfried
                    • Sep 2019
                    • 81
                    • Cameroun
                    #29
                    Please help me fix this file
                    • kayitsiz
                      • May 2017
                      • 18
                      • istanbul
                      #30
                      thanks
                      • djharold
                        • Aug 2015
                        • 247
                        • COLOMBIA
                        #31
                        Originally posted by ivanxxx
                        try this one
                        thanks
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12347
                          #32
                          Sony Fit 15E
                          • scorpion_3477
                            • Aug 2022
                            • türkiye
                            #33
                            Hello there. I need bios file for sony SVF1521NSTW DA0HK9MB6D0 REV.D please help.
                            • peste
                              • Dec 2016
                              • 13661
                              • ROMANIA
                              #34
                              make a copy of the original bios of the laptop and try post #2
                              • epoy
                                • Jun 2016
                                • 43
                                • phillipines
                                #35
                                thanks you!!!!!
                                • iga
                                  • Nov 2024
                                  • Туркменистан
                                  #36
                                  thank you guys, u r the best
                                  • Ahari
                                    by Ahari
                                    I...
                                    08-13-2025, 06:12 AM
                                  • mkdj
                                    by mkdj
                                    Dear all,
                                    10-19-2025, 04:41 AM
                                  • Habble7
                                    by Habble7
                                    Suspected Cause:
                                    Troubleshooting Attempts:
                                    05-22-2025, 07:28 AM
                                  • haitham sharabati
                                    [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                    by haitham sharabati
                                    Hello engineers 😀,
                                    I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                    🔧 Device Info:
                                    - Model: HP 15-da2007ne
                                    - Product Number: 8XF55EA#ABV
                                    - Serial Number: CND0338P0D
                                    - CPU: Intel Celeron N4000
                                    - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                    💀 Problem:😅
                                    - Device shows “Administrator Password”...
                                    08-07-2025, 04:54 AM
                                  • Citymin
                                    by Citymin
                                    S/N : 5RNK9FFT70...
                                    08-05-2025, 05:12 AM
