15-ab219na bios help
  • dj_ricoh
    • 2073
    hello fellow technicians !
    can someone help me with this bios?
    i got charging led on white charging the battery to OJ, tough it does not trigger to switch on.
    3.3v from power button does drop. 0 activity on bios and for some reason no voltage on the bios.
    3.3v its present on the battery socket, eliminating the fact that the 3.3v not present.
    Charging and DEAD at the same time. Schrodinger Cat FFS
  • dj_ricoh
    • 2073
    Re: 15-ab219na bios help
    is there a board view or a diagram for this notebook?
    any help will be nice!
    thanks
    • Djosla
      • Dec 2012
      • 246
      • Montenegro
      here is clean extracted bios from hp support...
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        @djosla
        brzi od mene za trenutak...
        cudni ovi novi HP bios-i
        Im Back... sort of...
        • dj_ricoh
          • 2073
          ok!
          so it powers up and it blinks 3 long and 2 short
          3 / 2
          The embedded controller has timed out waiting for BIOS to return from memory initialization
          • Djosla
            • Dec 2012
            • 246
            • Montenegro
            what is the board code ? can you post a picture ?
            • dj_ricoh
              • 2073
              the screen goes black from that green tone.
              no display ofc
              • Djosla
                • Dec 2012
                • 246
                • Montenegro
                Well since this is a soc system which is starting and the memory controller is in cpu i would try to reflow or reball that cpu...
                • dj_ricoh
                  • 2073
                  reballing its not a option for me.
                  making this a class hobby and having all the tools except the bga station.
                  got this notebook from a friend who gave quite a lot of free stuff, so i kinda own him this board to fix.
                  reflow i will do.
                  i just got the RMA-218 kingbo
                  • Djosla
                    • Dec 2012
                    • 246
                    • Montenegro
                    ok post results...
                    • dj_ricoh
                      • 2073
                      Hy.
                      Back again to this HP.
                      I reflow the CPU and I'm up and running.
                      Now there is no info in BIOS .
                      Nothing no serial no ID
                      Can someone help me infuse the serial nr ?
                      • ala_borbe
                        aka Donald
                        • 1625
                        • Malta
                        try nthis? if does not work search for hp nb dmi fit tool
                        • dj_ricoh
                          • 2073
                          very good! Thank you
                          Its up now.
                          • abbas_govani
                            • Jul 2013
                            • 89
                            • India
                            hello brothers,
                            i have hp 15-ab215tx laptop with dax1bdmb6f0 Rev F. board.
                            it is powering up but no display capslock blinking 5 times slow follow by 3 fast.
                            the embedded controller has timed out waiting for the BIOS
                            updated firmware but no sucess..
                            any suggession ?
                            thanks.
                            • stingerchamp
                              • Sep 2020
                              • 425
                              • Pakistan
                              Originally posted by abbas_govani
                              hello brothers,
                              any suggession ?
                              thanks.
                              this capslock blink error is happening with HP laptops more often.
                              You try replacing RAM stick and check if it boots and share results.
                              • cr4zychriss
                                by cr4zychriss
                                • Rebrand: PC Specialist
                                11-14-2025, 04:04 PM
                              • pirati
                                by pirati
                                10-27-2025, 04:20 PM
                              • Vesko356
                                by Vesko356
                                08-11-2023, 03:27 AM
                              • istvanszasz99
                                Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                by istvanszasz99
                                Product Name: Razer Blade 15 (2022)
                                Product ID: RZ09-0421
                                Motherboard: CH580
                                BIOS Versions I work with: 2.02 & 2.06
                                Bios File Size: 32,768 KB
                                Dear Forum Readers!
                                I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                                I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                                The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                                !!! MY RAZER BLADE...
                                11-24-2025, 05:52 PM
                              • jbonavita
                                by jbonavita
                                Some issues
                                Things I tried
                                04-29-2025, 09:38 PM
