Bios Asus N750JV (Dump Available)
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Hello Guys
    I have a Asus N750JV that give a black screen on boot, with the hdd led flashing every 5 seconds.
    This is a 8Mb bios and the one provided on Asus is not the same:
    Dump 8 192Kb
    Bios Asus 6 146Kb
    I'm posting my dump plus the one from Asus, If a bios expert can help, I'm most grateful !
    Dump from Dead Pc :
    https://mega.nz/#!LY8SwRaa!DQQha7UAS...GCvG8UJ969eu3E
    Bios From Asus Site:
    https://mega.nz/#!GZsHgKLL!Mcho_Ktba...RpesxIVaSwQK_g
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Re: Bios Asus N750JV (Dump Available)
    Please, anyone ?
    • cyberhack
      • Feb 2013
      • 466
      • Uk
      Here i got from Russian site let us know if they work
      • passete
        Living=Sharing
        • Jun 2015
        • 487
        • France
        I got it also from a Russian site (a guy send me a mail), but now the pc boot's, but the file he send me a bios from the wrong model.
        Now the pc doesn't detected the second GPU, only the one from core i7.
        Look what I get when I try to update the bios from the easy flash interface :
        Well, I guess that this the reason that the Nvidia gpu is not detected.
        • passete
          Living=Sharing
          • Jun 2015
          • 487
          • France
          Thank you very MUCH buddy,
          the first one called : N750JV is the Good one, Nvidia 2gb Gpu is now detected.
          • dmartins
            David M
            • Apr 2014
            • 197
            • Lisbon
            I use this and dont work , wont recognize my 850M .. its a N750JV
            • mkdj
              by mkdj
              Dear all,
              10-19-2025, 04:41 AM
            • razor_amd
              by razor_amd
              12-15-2020, 07:07 PM
            • pirati
              by pirati
              10-27-2025, 04:20 PM
            • DynaxSC
              by DynaxSC
              06-14-2024, 03:49 PM
            • Ahari
              by Ahari
              I...
              08-13-2025, 06:12 AM
