Toshiba Salellite U840 bios need urgent
  • alihomee
    • Dec 2012
    • 1598
    • malaysia
    Toshiba Salellite U840 have no display i need bios this is original file plz as soon as possible
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: Toshiba Salellite U840 bios need urgent
    http://support.toshiba.com/support/d...eeText=3436384
    I've checked on toshiba-asia which have bios for your model N/A. try from toshiba.com find link above. I've managed to extract with WinRar then found by2160.fd...the size look same with your bios backup. so start to try bios from web no problem, before duo master (techman and ala) come out
    in my mind, your bios fit with version 1.60 ( same size 4mb) =su4sv160.exe
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      @meritosari
      you are on the right track..
      by looking with hxd bid=1433 so this should be the file
      Im Back... sort of...
      • alihomee
        • Dec 2012
        • 1598
        • malaysia
        thanks you very much but problem not solve yet i think graphic or intel problem
        • to5it0
          by to5it0
          10-24-2025, 01:35 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • maanee11
          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
          by maanee11
          Hello Everyone,
          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
          In the website, you can only see specs etc.
          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
          11-08-2025, 04:08 AM
        • m1ch43lzm
          by m1ch43lzm
          Hi everyone
          09-06-2025, 05:47 PM
        • HOHA
          BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
          by HOHA
          Hi can you help me
          I did not find the BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
          IP3_TN16S_MB_V30_20210901A
          This is the old BIOS file, it is corrupted​...
          10-20-2024, 08:22 AM
