BIOS bin file for SAMSUNG N140
  • pcnetch
    • Aug 2013
    • 125
    • Sri Lanka
    Hello friend, Please Upload if you have SAMSUNG n140 Bios bin file. Thanks
  • naeemshahzad
    • Jan 2015
    • 129
    • uae
    Re: BIOS bin file for SAMSUNG N140
    try this one if not correct than send to me full detail motherboard model number graphic chip number kbc ic number .
    • pcnetch
      • Aug 2013
      • 125
      • Sri Lanka
      Thanks my dear. I will try this and tell you what happened
      • pcnetch
        • Aug 2013
        • 125
        • Sri Lanka
        Dear, your bios file ok but problem still same.When It boots, This message comes "Hardware Malfunction, Call your hardware vendor for support. Parity check / memory parity error, the system has halted." When try to install new os , does not detect bootable pen drive in the bios. What is it? I re flashed bios. Re balled ICH. Same result. Help...... Thanks
        • meritosari
          • Oct 2010
          • 774
          • Indonesia
          Look like RAM issue, try another RAM that you know very good. what specification of RAM that you used?
          • razycool0
            • Oct 2021
            • 10
            • maroc
            THANKS FOR THE FILE (SAMSUNG N140 BIOS BIN)
            • Forest79
              by Forest79
              However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
              07-23-2023, 07:39 AM
            • maanee11
              Help to get Lenovo BIOS bin file for Thinkpad T560
              by maanee11
              Hello Everyone,
              I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
              https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
              In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
              05-15-2022, 11:59 AM
            • Sebastian Codrean
              BIOS file for ASUS F542UN laptop
              by Sebastian Codrean
              Hello to all of you! I need help with a BIOS file.
              The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
              So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
              02-20-2025, 10:25 AM
            • Fr33man
              BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
              by Fr33man
              I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
              *Novo button power on
              *Disconnected internal battery...
              09-23-2024, 01:16 PM
            • Kazik
              Samsung NP680Z5E NP670Z5E (mb: NIKE2-15-DC) BIOS file required
              by Kazik
              I received Samsung NP680Z5E laptop for repair. It is charging the battery (charging light on, the voltage on the battery confirms the charging process), but the laptop won't switch on. 3.3V present on the BIOS chip. Power switch checked (however the voltage on the switch is just below 1V - I have no clue if this is the right voltage). Cable connection between the power switch/USB logic board and the main motherboard was checked and is OK. I have no schematic or boardview and I'm also not the greatest specialist in motherboard repair.
              I'm thinking that the NO POWER...
              10-20-2022, 05:38 PM
