Samsung NP680Z5E NP670Z5E (mb: NIKE2-15-DC) BIOS file required
  • Kazik
    • Oct 2016
    • 53
    I received Samsung NP680Z5E laptop for repair. It is charging the battery (charging light on, the voltage on the battery confirms the charging process), but the laptop won't switch on. 3.3V present on the BIOS chip. Power switch checked (however the voltage on the switch is just below 1V - I have no clue if this is the right voltage). Cable connection between the power switch/USB logic board and the main motherboard was checked and is OK. I have no schematic or boardview and I'm also not the greatest specialist in motherboard repair.
    I'm thinking that the NO POWER problem might be related to the BIOS problem, so before going further with diagnostics I would like to reprogram the BIOS chip and check if it's going to solve the problem.
    Does anyone have a BIOS dump for Samsung NP680Z5E?
    Laptop model: NP680Z5E-X01UK
    Motherboard: NIKE2-15-DC
    BIOS: 64Mb (8MB)
    • 20992
    Re: Samsung NP680Z5E (mb: NIKE2-15-DC) BIOS file required
    BIOS: 64Mb (8MB)
    Make a backup and post it here .
    • Kazik
      • Oct 2016
      • 53
      Thank you for a quick reply.
      The BIOS dump attached.
      • Pedro Ramírez
        • Jul 2024
        • 21
        • Chile
        Hello dear colleagues, could you please help me with this corrupt BIOS? 🙌
        Please I can't get my file to work.
        Samsung NP670Z5E-X01CL
        S/N: JE9Z91HD400818N
        MB: NIKE2-15_DC
        • peste
          • 12859
          • ROMANIA
          MB: NIKE2-15_DC
          try..
          • Pedro Ramírez
            • Jul 2024
            • 21
            • Chile
            Excuse my question. Is this a file ready to use in my BIOS IC? I'm deeply grateful for your help.
            • peste
              • 12859
              • ROMANIA
              yes..write it on the chip and test it...
              • Pedro Ramírez
                • Jul 2024
                • 21
                • Chile
                It didn't work my dear friend
                • shiyab
                  • Sep 2023
                  • 1483
                  • india
                  MB: NIKE2-15_DC
                  hi try
                  • Pedro Ramírez
                    • Jul 2024
                    • 21
                    • Chile
                    Originally posted by shiyab
                    hi try
                    Hello dear friend, thanks for the BIOS. It worked for me, but I've solved some problems: it doesn't recognize the GPU, and it doesn't recognize the MB and serial number information. What can I do to fix this?
                      • 20992
                      try this one.
                      • Citymin
                        by Citymin
                        S/N : 5RNK9FFT70...
                        08-05-2025, 05:12 AM
                      • iZakre
                        HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                        by iZakre
                        Hello everybody!
                        To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                        The thing is that I had installed TeamViewer and could log into the computer...
                        02-19-2023, 02:27 PM
                      • maanee11
                        Help to get Lenovo BIOS bin file for Thinkpad T560
                        by maanee11
                        Hello Everyone,
                        I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                        https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                        In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                        05-15-2022, 11:59 AM
                      • Sebastian Codrean
                        BIOS file for ASUS F542UN laptop
                        by Sebastian Codrean
                        Hello to all of you! I need help with a BIOS file.
                        The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                        So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                        02-20-2025, 10:25 AM
                      • Fr33man
                        BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
                        by Fr33man
                        I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
                        *Novo button power on
                        *Disconnected internal battery...
                        09-23-2024, 01:16 PM
