asus TP300L-DW07H
  • alihomee
    • Dec 2012
    • 1576
    • malaysia
    asus TP300L-DW07H
    need bios file for this model.........orignal is attached
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: asus TP300L-DW07H
    what is wrong with it???
    your post says TP300LD but bios says TP300LA
    try and se if it works....
    Im Back... sort of...
    • alihomee
      • Dec 2012
      • 1576
      • malaysia
      yes u r correct its LA......
      • alihomee
        • Dec 2012
        • 1576
        • malaysia
        i flashed with ur file ....it turns on but with no display....one more thing i noticed that with orignal file it takes .45 amps on power supply but with ur file it only consume .24 amps,,,,,,,,,,i think we need a good working dump
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          can you try this
          • alihomee
            • Dec 2012
            • 1576
            • malaysia
            its a intel mobo without graphic chip
            • alihomee
              • Dec 2012
              • 1576
              • malaysia
              and its a LA not LD......thanks for reply.......
              • kpritchard
                • Aug 2013
                • 4
                I have a TP300LA that turns on but doesn't turn on backlight in the LCD (even with a replacement). Is this the issue you had? Did you find a resolution?
                • ala_borbe
                  aka Donald
                  • 1625
                  • Malta
                  if its ati vga reflow vga
                  • kpritchard
                    • Aug 2013
                    • 4
                    Mine was the LA and intel only. I found a fuse beneath the LVDS connector, beige colored with an H on it that had blown. Bridged it and I have backlight again.
                    So, for searching purposes:
                    Asus Q302L TP300LA motherboard, no backlight -- fuse is located beneath the board, under the connector and is stamped with an H! I am so relieved this resolved my issue
                    Closeup of fuse attached. Again this is for no backlight, but external video is fine issues.
                    • inkboss15
                      • Feb 2015
                      • 6
                      • Philippines
                      ASUS TP300L need schema
                      • helplsn
                        • Aug 2016
                        • 11
                        • Nepal
                        Default asus TP300L-q302L bios
                        • jhuztine2881
                          • 36
                          • Philippines
                          i have an asus TP300LA, after boot up the display going to flicker and the laptop sleep itself...
                          anyone knows this problem? tnx in advance brothers.
                          • jhuztine2881
                            • 36
                            • Philippines
                            did you find a schema for tp300l?
                            • Bonzas
                              • 471
                              • Indonesia
                              did anyone find schema or boarview ?
                              i have this laptop with charging issue, maybe someone can help my problem ?
                              thanks before
                              • bricewerry@live.fr
                                • Mar 2018
                                • 3
                                • France
                                I have that https://cloud.werry.ovh/s/Gwt2tF8Q8LQYA7B
                                • samy alexi
                                  • Mar 2017
                                  • 93100
                                  Merci beaucoup mes amis
                                  • heta1000
                                    • Jul 2013
                                    • 33
                                    • egypt
                                    thanks
                                    • shahzad butt
                                      • Mar 2015
                                      • 5
                                      • saudia
                                      Your post says tp300ld but bios says tp300la
                                      Try and se if it works....
                                      thanks bro u r always amazing working 100%
                                      • kodox
                                        • Jul 2017
                                        • 322
                                        • Indonesia
                                        Originally posted by bricewerry@live.fr
                                        Thanks...
                                          ASUS Transformer TP300LA-DW169H Hybrid (2-in-1) Book Flip Specification for Upgrade or Repair
                                          This specification for the ASUS Transformer TP300LA-DW169H Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TP300LA-DW169H boardview and TP300LA-DW169H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 AM
                                          ASUS Transformer TP300LA-DW114H Hybrid (2-in-1) Book Flip Specification for Upgrade or Repair
                                          This specification for the ASUS Transformer TP300LA-DW114H Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TP300LA-DW114H boardview and TP300LA-DW114H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        • Sebastian Codrean
                                          BIOS file for ASUS F542UN laptop
                                          by Sebastian Codrean
                                          Hello to all of you! I need help with a BIOS file.
                                          The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                          So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                          02-20-2025, 10:25 AM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • rickjansen01
                                          Asus FA707 corrupt Bios File
                                          by rickjansen01
                                          Hello Guy's
                                          Can somebody help me whit this problem
                                          Asus FA707 bios file is corrupt
                                          sn T3NRCXCZR00Y117
                                          original file uploaded
                                          Regards chris...
                                          04-20-2025, 07:12 AM
