hp folio 9470m
  • kay6ix
    • Oct 2022
    • nigeria
    #141
    Re: hp folio 9470m
    Hi can i pls get a working bios file for my Hp folio 9470m # board number 6050A2514101-mb-A03 bios bin
    • peste
      • Dec 2016
      • 13661
      • ROMANIA
      #142
      Re: hp folio 9470m
      post the original bios even if it is corrupted..
      • tullar
        • Mar 2019
        • kenya
        #143
        Re: hp folio 9470m
        100% it works nicely
        • AHED
          • Aug 2020
          • 6
          • maroc
          #144
          Re: hp folio 9470m
          Originally posted by imranromi
          6050a2514101-mb folio 9470m
          working 100% ok check bios.
          thank u bro .work for me
          • dqtech
            Badcaps
            • Jul 2018
            • 639
            • N/A
            #145
            thanks
            • Merokabe
              • Aug 2021
              • Kenya
              #146
              Re: hp folio 9470m
              Thanks, confirmed working.
              • ashr88
                • Mar 2023
                • 62
                • United Kingdom
                #147
                Hi, I have an bios password HP Folio 9470M also with the previous owners "property of" notice at boot which I need removing. This is the bios dump. Thank you.
                • peste
                  • Dec 2016
                  • 13661
                  • ROMANIA
                  #148
                  post the S/N, the motherboard model, etc.
                  • ashr88
                    • Mar 2023
                    • 62
                    • United Kingdom
                    #149
                    S/N: CNU4059VSL
                    Motherboard part number: 717844-601
                    • skazide
                      • Jul 2015
                      • 143
                      • morocco
                      #150
                      try
                      • ashr88
                        • Mar 2023
                        • 62
                        • United Kingdom
                        #151
                        Originally posted by skazide
                        try
                        This is constantly not writing correctly? I even replaced the chip and used a different programming tool? Any ideas?
                        • ashr88
                          • Mar 2023
                          • 62
                          • United Kingdom
                          #152
                          • ovidox
                            • Sep 2024
                            Please I don't know or understand how to use any of the guides or tools like RCUnlocker ..
                            which gives me "MISSING UNLOCKABLE CONTENT" when i drag and drop the 68IBD.BIN file
                            I required help to reset / remove the BIOS pass word on my old HP EliteBook 9470m laptop
                            Laptop - serial : CNU32990FJ --- Motherboard part number: 702849-601 ( i think)
                            It's has been years since I have needed to enter the BIOS but I need to change the settings so my newer RAM can run at 1600 mhz instead of 800 mhz.
                            I have already tried the method of removing the CMOS battery etc or getting the laptop serial number in windows and then going to the (bios- pw. org) website to get the reset code but this code doesn't work for me.
                            My bios is on a BIOS chip and needs a physical EEPROM reader or a BIOS BIN file reader program. I do not have the technical skills to remove the bios chip/read it/flash it/re install it or the program to read the BIOS BIN file.
                            I know there is a way you can ask HP to send you an "SMC. bin" file from HP which you can use on an USB and boot from BUT they are impossible to reach, deal with and explain that you need that tool/file to do it yourself.
                            SO
                            If upload/send my current BIOS "file. BIN" ... can someone to check with their BIOS reader and let me know the pass word? Please can anyone help?
                            I think the moderator has helped me and my current BIOS file should be in a zip file now below. thank you
                            • jcdelvalle
                              @JCdelValle
                              • Oct 2024
                              • Mexico
                              #154
                              Hello everyone!
                              peste are you helping to create a correct BIN file for this HP model? (HP Elitebook Folio 9470m) , in affirmative case, which information is required to create one?
                              Regards!!!
                              Atte. jcdelvalle
                              • peste
                                • Dec 2016
                                • 13661
                                • ROMANIA
                                #155
                                post the S/N, the original bios of the laptop, the motherboard model, etc,read the forum rules .
                                • chumatez
                                  • Jan 2021
                                  • 23
                                  • Nigeria
                                  #156
                                  I need help in cleaning my bios
                                  the fan is blowing but no display on the screen , i have tried some of the uploaded files on the forum but non worked
                                  hp folio 9470m
                                  board number 6050A2569401 -MB- A01
                                  • peste
                                    • Dec 2016
                                    • 13661
                                    • ROMANIA
                                    #157
                                    hp folio 9470m
                                    post the S/N,etc..
                                    • chumatez
                                      • Jan 2021
                                      • 23
                                      • Nigeria
                                      #158
                                      hp folio 9470m
                                      board number 6050A2569401 -MB- A01​
                                      Serial CNU304B7XR (This motherboard have been replaced before.)
                                      Product C6Z63UT#ABA#
                                      • shiyab
                                        • Sep 2023
                                        • 1620
                                        • india
                                        #159
                                        hp folio 9470m
                                        HI try
                                        • chumatez
                                          • Jan 2021
                                          • 23
                                          • Nigeria
                                          #160
                                          Originally posted by shiyab
                                          HI try
                                          I tried it but did not work 😭😭😭 , thanks for your help , i will inform the customer to replace the motherboard
                                          • m1ch43lzm
                                            Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                            by m1ch43lzm
                                            Hi everyone
                                            I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                            Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                            Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                            There's also an extra OTP Secu.R...
                                            09-06-2025, 05:47 PM
                                            HP EliteBook Folio EliteBook Folio G1 Notebook Specification for Upgrade or Repair
                                            This specification for the HP EliteBook Folio EliteBook Folio G1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook Folio G1 boardview and EliteBook Folio G1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 06:34 AM
                                            HP EliteBook Folio EliteBook Folio G1 + USB-C Universal Dock Notebook Specification for Upgrade or Repair
                                            This specification for the HP EliteBook Folio EliteBook Folio G1 + USB-C Universal Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook Folio G1 + USB-C Universal Dock boardview and EliteBook Folio G1 + USB-C Universal Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                            09-06-2024, 06:30 AM
                                            HP EliteBook Folio EliteBook Folio G1 Notebook PC (ENERGY STAR) Notebook Specification for Upgrade or Repair
                                            This specification for the HP EliteBook Folio EliteBook Folio G1 Notebook PC (ENERGY STAR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook Folio G1 Notebook PC (ENERGY STAR) boardview and EliteBook Folio G1 Notebook PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                            09-06-2024, 05:30 AM
