hp folio 9470m
  • mabearce1
    • Jan 2022
    • 11
    Re: hp folio 9470m
    ya, I think it is just dead too figured I would get something. musta messed it up somewhere.
    • zurvanielle
      • Feb 2017
      • 137
      • Philippines
      #102
      Re: hp folio 9470m
      Originally posted by imranromi
      6050a2514101-mb folio 9470m
      working 100% ok check bios.
      TNX...it works....
      • Alassane
        • Oct 2018
        • 65
        • MALI
        #103
        Re: hp folio 9470m
        THANK YOU.
        • Ian007
          • Mar 2022
          • Indonesia
          #104
          Re: hp folio 9470m
          This work..
          • Usedcom
            Usedcom
            • Dec 2015
            • 24
            • Polska
            #105
            Re: Hp folio 9470m Working dump
            Working.
            ok, thanks
            • kba81
              • Mar 2022
              • 8
              Re: hp folio 9470m
              6050a2514101-MB-A03 / w25q128FVSG
              No reaction to power button.Charging led blinking white and orange when charger connected.
              After reading chip I`ve got information "chip is empty" so I used tested file FOLIA 9470M OK.zip from #6 and Elitebook Folio 9470M.zip from #72.After wtiting when I press Verify I`m getting an error "flash check error address:10h".Then when I`m reading it it says "chip is empty".I`m using ezp2019 which is detecting the chip model.I removed chip from mb, of course.
              I presume chip is faulty and I`m thinking to buy brand new one.Am I right or wrong?
              • Udara Umayanga
                • May 2020
                • 11
                • Sri Lanka
                #107
                Re: hp folio 9470m
                I need diagram for
                folio 9470m
                • Vesko356
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  #108
                  Re: hp folio 9470m
                  Originally posted by Udara Umayanga
                  I need diagram for
                  folio 9470m
                  Schematic request go here.
                  Become a Badcaps supporter
                  Thanks to all supporters.​
                  • dmarsh3
                    • Jun 2022
                    • South Africa
                    #109
                    Re: hp folio 9470m
                    Hi, is anyone able to unlock a dump file from an HP Elitebook Folio 9470m for me, I have tried using RCUnlocker but it gives me a python error something about a utf-8 codec can't decode a byte - while it still creates an unlocked file which does differ from the original programming it back into the flash chip the password has not been removed, I cannot get into the BIOS setup. Dump file attached.
                    Thanks!
                    • yukselen
                      yukselen
                      • Jun 2021
                      • 37
                      • türkiye
                      #110
                      Re: hp folio 9470m
                      thank you it is working
                      • gitsfarmaz
                        Professnal tech
                        • Apr 2017
                        • 30
                        • Kenya
                        #111
                        Re: hp folio 9470m
                        Folio 9470m-6050A2514101-MB-A03
                        TRY THIS IT WORKED FOR ME, ALSO COMES WITH SERIAL ...UNDER BIN FILES JUST SELECT ALL FILES TO VIEW THE FILE FROM PROGRAMMER
                        • Magnusa2
                          • Jul 2017
                          • 66
                          • India
                          #112
                          Re: hp folio 9470m
                          thanks working
                          • wolf3d.exe
                            • Jan 2023
                            • 33
                            Re: hp folio 9470m
                            I have couple 9470m's to unlock. The ones with w25q128xV BIOS chip, they have UEFI Bios With Win8 pro stickers. These I can read unlock and write back no issues. They are easily get unlocked. But the others they have mt25ql128ab BIOS chip, they have Win7 Pro stickers. Chips get detected. I can read them. Unlock them no problem. When I want to write them they fail at verification. What I am missing here ?? Any help greatly appreciated. I read the chips removed, I use ch341 programmer.
                            • peste
                              • Dec 2016
                              • 13199
                              • ROMANIA
                              #114
                              Re: hp folio 9470m
                              stop the verification and write one like this, see what happens
                              • wolf3d.exe
                                • Jan 2023
                                • 33
                                Re: hp folio 9470m
                                Goes well without verifying but the laptop, power light goes between white and orange. No boot, does not power on. I tried this on two laptops with same MICRON chips. In this (https://www.youtube.com/watch?v=96crJwtE1ls) video, the guy uses same chip, same controller and same programmer software with success. It is really annoying.
                                • peste
                                  • Dec 2016
                                  • 13199
                                  • ROMANIA
                                  #116
                                  Re: hp folio 9470m
                                  use one of these programs.
                                  https://www.badcaps.net/forum/showpo...6&postcount=10
                                  https://www.badcaps.net/forum/showpo...04&postcount=7
                                  • wolf3d.exe
                                    • Jan 2023
                                    • 33
                                    Re: hp folio 9470m
                                    Tried ASProgrammer with a .bin file that I downloaded from this thread. It worked. But I dont want to flash all the laptops with same bios (or is it ok?) How can I make sure that my dump is ok? (dumping multiple times, I do)
                                    Two laptops that I tried was unlocked with RCLocker. Probably that is the culprit?
                                    • peste
                                      • Dec 2016
                                      • 13199
                                      • ROMANIA
                                      #118
                                      Re: hp folio 9470m
                                      bios unlocked try it..
                                      • wolf3d.exe
                                        • Jan 2023
                                        • 33
                                        Re: hp folio 9470m
                                        Thank you for this. File that I attached at #117 worked for me. But my question was is it ok to flash multiple BIOS with same file? Also which program did you use to unlock? RCUnlocker or HPunlocker ?
                                        • Vesko356
                                          VIP Moderator
                                          • Aug 2018
                                          • 4386
                                          • Bulgaria 🇧🇬
                                          #120
                                          Re: hp folio 9470m
                                          No. Every machine has unique data in it's factory bios, like the DMI data, also Intel ME firmware and so on. So the proper way to do it is to unlock the factory dump.
                                          • m1ch43lzm
                                            Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                            by m1ch43lzm
                                            Hi everyone
                                            I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                            Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                            Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                            There's also an extra OTP Secu.R...
                                            09-06-2025, 05:47 PM
                                            HP EliteBook Folio EliteBook Folio G1 Notebook Specification for Upgrade or Repair
                                            This specification for the HP EliteBook Folio EliteBook Folio G1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook Folio G1 boardview and EliteBook Folio G1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 06:34 AM
                                            HP EliteBook Folio EliteBook Folio G1 + USB-C Universal Dock Notebook Specification for Upgrade or Repair
                                            This specification for the HP EliteBook Folio EliteBook Folio G1 + USB-C Universal Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook Folio G1 + USB-C Universal Dock boardview and EliteBook Folio G1 + USB-C Universal Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                            09-06-2024, 06:30 AM
                                            HP EliteBook Folio EliteBook Folio G1 Notebook PC (ENERGY STAR) Notebook Specification for Upgrade or Repair
                                            This specification for the HP EliteBook Folio EliteBook Folio G1 Notebook PC (ENERGY STAR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook Folio G1 Notebook PC (ENERGY STAR) boardview and EliteBook Folio G1 Notebook PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                            09-06-2024, 05:30 AM
