CLEAN Bios file Toshiba L875-139 PSKFNE NEED
  • HABIBOU11
    • Jul 2015
    • 50
    • ALGERIA
    hi
    this is the original dump protected by password uploaded
    please help
    thanx
    Хвала Аллаху, Господу миров
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: CLEAN Bios file Toshiba L875-139 PSKFNE NEED
    here is your bios, but you have 2 eproms on board, you need to write both
    one is 2mb, other 4mb
    Im Back... sort of...
    • HABIBOU11
      • Jul 2015
      • 50
      • ALGERIA
      Thanx so much friend
      • HABIBOU11
        • Jul 2015
        • 50
        • ALGERIA
        I' HAVE JUST FLSHED THE 4mB DUMP BECAUSE IT IS THE SAME VERSION
        & THATS WORKING
        THANX
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          ok, great, i did not know its the same version
          • to5it0
            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
            by to5it0
            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
            I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
            This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
            I have opened the laptop and identified the main BIOS chip...
            10-24-2025, 01:35 AM
          • zenius
            by zenius
            12-08-2024, 06:13 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • maanee11
            Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
            by maanee11
            Hello Everyone,
            I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
            It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
            In the website, you can only see specs etc.
            I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
            11-08-2025, 04:08 AM
          • m1ch43lzm
            Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
            by m1ch43lzm
            Hi everyone
            I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
            Programmer models: XGecu TL866II Plus / T48 / T56 / T76
            Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
            There's also an extra OTP Secu.R...
            09-06-2025, 05:47 PM
