probook 440 G1 bios
  • masud
    • Jul 2011
    • 317
    • Bangladesh
    probook 440 G1 bios
    need probook 440 G1 bios file, please help.
    thanks.
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: probook 440 G1 bios
    post your old bios and i will fix it for you
    Im Back... sort of...
    • ridamouh159
      • Nov 2014
      • 365
      • maroc
      its ok and working sure
      • ridamouh159
        • Nov 2014
        • 365
        • maroc
        and you caan use probook450 g1 it is the same
        • leofon
          • Dec 2021
          • 6
          • mexico
          Hello, I tried to flash the bios chip but it gives me this message in neo programmer: "File size larger than IC size"
          am i doing something wrong?
          the bios chip is a MX25L6473E
          :llorando:
          • hardware1
            • Sep 2021
            • 2949
            • N/A
            :llorando:
            You are right, his file was larger by 1KB (200h).
            If that file doesn't fix your Problem, upload your Original Backup and write your device Serial Number.
            all donations are welcome,
            • to5it0
              Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
              by to5it0
              Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
              I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
              This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
              I have opened the laptop and identified the main BIOS chip...
              10-24-2025, 01:35 AM
            • studdy05
              Bricked HP Probook 450 G7 Bios questions
              by studdy05
              Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
              Ive got...
              07-08-2025, 09:24 PM
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
            • maanee11
              Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
              by maanee11
              Hello Everyone,
              I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
              It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
              In the website, you can only see specs etc.
              I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
              11-08-2025, 04:08 AM
            • m1ch43lzm
              Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
              by m1ch43lzm
              Hi everyone
              I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
              Programmer models: XGecu TL866II Plus / T48 / T56 / T76
              Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
              There's also an extra OTP Secu.R...
              09-06-2025, 05:47 PM
