Asus x55u bios needed pls
  • Levi
    • May 2014
    • 59
    • Ghana
    Hi there, pls i need asus x55u bios dump urgentli. Thks in advance
  • Levi
    • May 2014
    • 59
    • Ghana
    Re: Asus x55u bios needed pls
    Hi there pls need bios dump for asus r503u amd E2 vision. The problem with this unit is a no post or display. From the customer, the machine was forcefully shutdown. As a result when trying to power on subsequently, nothing on screen.pls help pals
    • Agent24
      I see dead caps
      • Oct 2007
      • 4950
      • New Zealand
      Did you try reset BIOS?
      -David VanHorn
      • rs232killer
        • Feb 2015
        • 89
        • Portugal
        Hi
        on the search for this bios found this post
        Hope it helps someone
        Regards
        Rs
        • Pascal Komlassan
          • Jan 2017
          • 806
          • TOGO
          Originally posted by rs232killer
          Hi
          Regards
          Rs
          very good
          https://www.badcaps.net/forum/attach...3&d=1455977004
          • Spork Schivago
            • Mar 2012
            • 4734
            • United States of America
            Was the customer doing a BIOS update when they forcefully shut it down? If not, I would check other things first. I would physically look at the capacitors, especially the ones around the CPU, to see if any of them have swollen tops. If that was good, I would try checking the RAM, to see if one of the RAM sticks died. If there's more than one stick, you can remove them all and try just one stick at a time, if you don't have a known good stick of RAM to try.
            Then I'd look at the power supply. Using a power supply tester usually isn't enough. The power supply can be turning on but still have bad capacitors inside. The voltages can show good until the power supply is under load.
            -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
            • Spork Schivago
              • Mar 2012
              • 4734
              Here's a BIOS from Asus's website for the r503u. I just went to their site and typed in r503u in the search box. It only returned one search result. I clicked it and downloaded the BIOS. It's version 423 and they say:
              Code:
              Fix there is not U3 device boot option in popup menu when insert U3 device into U3 port
              As always, before you try flashing, I would create a backup of the current BIOS, even if you suspect it's corrupt, unless it's physically damaged and you have no other options. That way, if it's the wrong BIOS or something goes wrong, you can just restore it to the condition it's currently in.
              **EDIT: Whoops! I didn't realize the original post was almost over 2 years ago. Sorry!
              Last edited by Spork Schivago; 07-16-2017, 08:08 PM. Reason: Helped resurrect a dead thread
              • grimacelord
                by grimacelord
                07-10-2025, 02:52 PM
              • throwaway327
                by throwaway327
                Model No: RC72LA
                Serial No: SBNVKD001014459
                06-18-2025, 05:52 PM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • exerion5000
                Bios Needed For Asus X515EA Pcb X415EA R2.0
                by exerion5000
                Asus X515EA_No Power_GD25B127D@SOIC8.rar
                Hi Everyone! , i need repair the original bios corruptes of this model machine (Bios Needed For Asus X515EA Pcb X415EA R2.0) , the unit no power on , i test several bios for this model with some issues maybe related to especific version (keyboard partially work or no work , SSD no detected ,Etc ) so y let more data below if help , many thanks in advance!...
                02-17-2025, 01:34 PM
              • lrouw84
                by lrouw84
                Hi there,
                01-28-2023, 01:31 PM
