Asus x55u bios needed pls
  • Levi
    • May 2014
    • 59
    • Ghana
    Hi there, pls i need asus x55u bios dump urgentli. Thks in advance
  • Levi
    • May 2014
    • 59
    • Ghana
    Re: Asus x55u bios needed pls
    Hi there pls need bios dump for asus r503u amd E2 vision. The problem with this unit is a no post or display. From the customer, the machine was forcefully shutdown. As a result when trying to power on subsequently, nothing on screen.pls help pals
    • Agent24
      I see dead caps
      • Oct 2007
      • 5037
      • New Zealand
      Did you try reset BIOS?
      -David VanHorn
      • rs232killer
        • Feb 2015
        • 89
        • Portugal
        Hi
        on the search for this bios found this post
        Hope it helps someone
        Regards
        Rs
        • Pascal Komlassan
          • Jan 2017
          • 809
          • TOGO
          Originally posted by rs232killer
          Hi
          Regards
          Rs
          very good
          https://www.badcaps.net/forum/attach...3&d=1455977004
          • Spork Schivago
            • Mar 2012
            • 4734
            • United States of America
            Was the customer doing a BIOS update when they forcefully shut it down? If not, I would check other things first. I would physically look at the capacitors, especially the ones around the CPU, to see if any of them have swollen tops. If that was good, I would try checking the RAM, to see if one of the RAM sticks died. If there's more than one stick, you can remove them all and try just one stick at a time, if you don't have a known good stick of RAM to try.
            Then I'd look at the power supply. Using a power supply tester usually isn't enough. The power supply can be turning on but still have bad capacitors inside. The voltages can show good until the power supply is under load.
            -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
            • Spork Schivago
              • Mar 2012
              • 4734
              Here's a BIOS from Asus's website for the r503u. I just went to their site and typed in r503u in the search box. It only returned one search result. I clicked it and downloaded the BIOS. It's version 423 and they say:
              Code:
              Fix there is not U3 device boot option in popup menu when insert U3 device into U3 port
              As always, before you try flashing, I would create a backup of the current BIOS, even if you suspect it's corrupt, unless it's physically damaged and you have no other options. That way, if it's the wrong BIOS or something goes wrong, you can just restore it to the condition it's currently in.
              **EDIT: Whoops! I didn't realize the original post was almost over 2 years ago. Sorry!
              Last edited by Spork Schivago; 07-16-2017, 08:08 PM. Reason: Helped resurrect a dead thread
              • grimacelord
                by grimacelord
                07-10-2025, 02:52 PM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • throwaway327
                by throwaway327
                Model No: RC72LA
                Serial No: SBNVKD001014459
                06-18-2025, 05:52 PM
              • ArkzG
                [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                by ArkzG
                Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                What I currently have available:
                - Model: FA506NF (2021)
                - BIOS chip: GD25LQ16 (16Mbit/2MB)
                - Tools: CH341A programmer ready to use
                Does anyone have either a clean 2MB .bin dump of this model,...
                09-26-2025, 09:34 PM
              • kodox
                Asus ExpertBook B1400CB Bios Dump Needed
                by kodox
                need original bios dump, original bios has flashed by other technician before me.
                attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                unit info:
                Model: Asus ExpertBook B1400CBA-0711A1235U
                S/N: R6NXNZ006657238
                CN: 7F6F
                Mainboard Code: B1500CBA R2.1...
                08-16-2025, 12:20 PM
