hp dv6 bios dump
  • asliyucegsm
    • Jun 2011
    • 347
    • Turkiye
    hp dv6 bios dump
    my friend
    dv6-3320st
    mainboard.DA0LX6MB6H1 REV.H
    Intel Core i5-460M 2.53GHz SLBZW (Socket G1 (rPGA988A))
    Graphics
    AMD Mobility Radeon HD 5650 (216-0772000) 1 GB GDDR3 (8xHynix H5TQ1G63BFR 12C)
    not.not.HP dv6-3320st MB: fan continuous operation DA0LX6MB6H1 rev.h
    the fan is running too fast with other bios
    bios dump 4mb must
    thanks
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: hp dv6 bios dump
    backup old and try this
    Im Back... sort of...
    • muhamad.sh
      • Apr 2017
      • 6
      • turkey
      thank u my dear
      • onur89
        • Jun 2017
        • Türkiye
        Thank you my dream
        • nts28
          • Nov 2015
          • 33
          • türkey
          thankyou
          • hardware-tec
            • Aug 2017
            • 4
            • Argentina
            Hola !! El primer archivos es el bios de la main y el segundo de que es??? dice EC
            • djharold
              • Aug 2015
              • 241
              • COLOMBIA
              el primer archivo es el main qu es el que da video, y el segundo es ec, que es donde guarda los seriales del equipo, con el main funciona la mayoria de los casos
              • daniel92
                • Jan 2015
                • 12
                • kenya
                the dump works fine, thanks.
                • SNS infotech
                  • india
                  dv6-2159tx bios needed
                  • Kamar
                    • May 2016
                    • 8
                    • india
                    good
                    • Pascal Komlassan
                      • Jan 2017
                      • 809
                      • TOGO
                      Good luck
                      • rohit_kool111
                        • Feb 2017
                        • 9
                        • nepal
                        hellow friend ....i want DA0ZQMMB6H0 REV:H bios
                          • 21197
                          Start a NEW thread ,you`ll get it .
                          • rohit_kool111
                            • Feb 2017
                            • 9
                            • nepal
                            what? i didn't understand
                              • 21197
                              The title of this thread is "hp dv6 bios dump"
                              You`re asking for a DA0ZQMMB6H0 bios, which is a acer E5-411. Use the search ,you`ll find previous threads with bios dumps.
                              • jou
                                • Nov 2016
                                • 3
                                • españa
                                thanks
                                • mkuzgun
                                  • 9
                                  • turkey
                                  THANKS bro
                                  • Gasasoft
                                    • Jan 2011
                                    • 4
                                    Thank you from me.
                                    Working dump without SN, SKU, etc.
                                    Must enter it manualy.
                                    • masoudpouramin
                                      • Nov 2018
                                      • iran
                                      thank you ok
                                      • thelibrary
                                        • Jul 2018
                                        • 18
                                        • philippines
                                        tested working !!
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                          💀 Problem:😅
                                          - Device shows “Administrator Password”...
                                          08-07-2025, 04:54 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
