hp dv6 bios dump
  • asliyucegsm
    • Jun 2011
    • 340
    • Turkiye
    hp dv6 bios dump
    my friend
    dv6-3320st
    mainboard.DA0LX6MB6H1 REV.H
    Intel Core i5-460M 2.53GHz SLBZW (Socket G1 (rPGA988A))
    Graphics
    AMD Mobility Radeon HD 5650 (216-0772000) 1 GB GDDR3 (8xHynix H5TQ1G63BFR 12C)
    not.not.HP dv6-3320st MB: fan continuous operation DA0LX6MB6H1 rev.h
    the fan is running too fast with other bios
    bios dump 4mb must
    thanks
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: hp dv6 bios dump
    backup old and try this
    Im Back... sort of...
    • muhamad.sh
      • Apr 2017
      • 6
      • turkey
      thank u my dear
      • onur89
        • Jun 2017
        • Türkiye
        Thank you my dream
        • nts28
          • Nov 2015
          • 33
          • türkey
          thankyou
          • hardware-tec
            • Aug 2017
            • 4
            • Argentina
            Hola !! El primer archivos es el bios de la main y el segundo de que es??? dice EC
            • djharold
              • Aug 2015
              • 239
              • COLOMBIA
              el primer archivo es el main qu es el que da video, y el segundo es ec, que es donde guarda los seriales del equipo, con el main funciona la mayoria de los casos
              • daniel92
                • Jan 2015
                • 12
                • kenya
                the dump works fine, thanks.
                • SNS infotech
                  • india
                  dv6-2159tx bios needed
                  • Kamar
                    • May 2016
                    • 8
                    • india
                    good
                    • Pascal Komlassan
                      • Jan 2017
                      • 806
                      • TOGO
                      Good luck
                      • rohit_kool111
                        • Feb 2017
                        • 9
                        • nepal
                        hellow friend ....i want DA0ZQMMB6H0 REV:H bios
                          • 20330
                          Start a NEW thread ,you`ll get it .
                          • rohit_kool111
                            • Feb 2017
                            • 9
                            • nepal
                            what? i didn't understand
                              • 20330
                              The title of this thread is "hp dv6 bios dump"
                              You`re asking for a DA0ZQMMB6H0 bios, which is a acer E5-411. Use the search ,you`ll find previous threads with bios dumps.
                              • jou
                                • Nov 2016
                                • 3
                                • españa
                                thanks
                                • mkuzgun
                                  • 9
                                  • turkey
                                  THANKS bro
                                  • Gasasoft
                                    • Jan 2011
                                    • 4
                                    Thank you from me.
                                    Working dump without SN, SKU, etc.
                                    Must enter it manualy.
                                    • masoudpouramin
                                      • Nov 2018
                                      • iran
                                      thank you ok
                                      • thelibrary
                                        • Jul 2018
                                        • 18
                                        • philippines
                                        tested working !!
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • grimacelord
                                          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                          by grimacelord
                                          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                          Motherboard model number: DA0PAMB46A1 REV: A
                                          Secondary motherboard model number: 0PAB
                                          SKU: 685K4UA
                                          Serial number is: 5CD3223BJP
                                          Recently reflashed this laptop with latest BIOS and once...
                                          05-07-2024, 08:06 AM
                                        • DynaxSC
                                          Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                                          by DynaxSC
                                          I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                                          It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                                          I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                                          11-06-2022, 05:22 PM
                                        • vinaypundith
                                          Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                                          by vinaypundith
                                          I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                                          So, I'm looking for a BIOS dump for this machine - a 16MB one....
                                          08-03-2024, 12:32 PM
