i need hp dv7-7227cl amd bios
  • dilip.pawar31
    • Nov 2014
    • 59
    • india
    i need the bios file hp dv7--7227cl
    48.4sv01.021
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: i need hp dv7-7227cl amd bios
    backup old bios
    Im Back... sort of...
    • dilip.pawar31
      • Nov 2014
      • 59
      • india
      Thank....................its working
      • dj_ricoh
        • 2073
        • uk
        What was wrong mate?
        • elshobokshy
          • Feb 2015
          • 5
          • sohag
          Thank
          • tysovyc
            • Mar 2017
            • 11
            • zimbabwe
            Re: i need help hp 14 ec
            Board code dinerinl-6050a2823301-mb-a01
            128kb ite it8987e
            Thanks for your support
              • 22279
              128kb ite it8987e
              This post is about a dv7-7227cl amd bios, start your own thread and give full laptop model number ,and post your bios backup .
              • m1ch43lzm
                by m1ch43lzm
                Hi everyone
                09-06-2025, 05:47 PM
              • to5it0
                by to5it0
                10-24-2025, 01:35 AM
              • Citymin
                by Citymin
                S/N : 5RNK9FFT70...
                08-05-2025, 05:12 AM
              • maanee11
                Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                by maanee11
                Hello Everyone,
                I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                In the website, you can only see specs etc.
                I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                11-08-2025, 04:08 AM
              • Forest79
                by Forest79
                07-23-2023, 07:39 AM
