hp 14-d017au
  • alihomee
    • Dec 2012
    • 1599
    • malaysia
    hp 14-d017au
    need bios file. motherboard code is OSAMU2-DIS_KB_HPC PV_MB_V1
  • alihomee
    • Dec 2012
    • 1599
    • malaysia
    Re: hp 14-d017au
    any one
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      Re: hp 14-d017au
      backup old and try this
      Im Back... sort of...
      • alihomee
        • Dec 2012
        • 1599
        • malaysia
        Re: hp 14-d017au
        thanks for reply but your file also no display .i attached orignal file that one also no display
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          Re: hp 14-d017au
          if this does not work, its not bios problem
          • Attif
            Attif
            • Dec 2016
            • 49
            • pakistan
            Re: hp 14-d017au
            your bios is okay dear ala_b0rbe
            • kus234
              • Jul 2015
              • 35
              • java
              Re: hp 14-d017au
              thx
              • to5it0
                Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                by to5it0
                Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                I have opened the laptop and identified the main BIOS chip...
                10-24-2025, 01:35 AM
              • m1ch43lzm
                Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                by m1ch43lzm
                Hi everyone
                I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                There's also an extra OTP Secu.R...
                09-06-2025, 05:47 PM
              • Citymin
                by Citymin
                S/N : 5RNK9FFT70...
                08-05-2025, 05:12 AM
              • maanee11
                Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                by maanee11
                Hello Everyone,
                I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                In the website, you can only see specs etc.
                I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                11-08-2025, 04:08 AM
              • GardevoirForEver
                Embedded Controller issues, living an absolute H*LL with my ASUS Vivobook Pro 16X OLED
                by GardevoirForEver
                I've been dealing with so many complications for months, trying to find and then fix the root cause of the issue I really need help and I have to solve this on my own (Going to Asus headquarters isn't an option for me. First, because I'm very stubborn and want to insist that I can fix this sort-of-myself somehow, and second, the location is too far away for me anyway).
                Right now I'm desperate trying to put an end to this nightmare, but OK, I'll do my best to be somewhat brief in explaining and relating the entire situation and context.
                The motherboard of my ASUS...
                11-15-2025, 04:30 PM
