bios dump needed for HP 15-d050sv
  • rookieme
    • Oct 2014
    • 403
    • Greece
    The motherboard is 01019BG00-491-G E162264 747152-501
    Thank you
  • rookieme
    • Oct 2014
    • 403
    • Greece
    Re: bios dump needed for HP 15-d050sv
    I found it at thread https://www.badcaps.net/forum/showthread.php?p=565130
    It seems it's the same with HP 255
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      backup old bios
      this one is from web update
      need to fix dmi and serial
      Im Back... sort of...
      • sajjadalisw@yahoo.com
        • Jan 2017
        • 15
        • uae
        thanx bro your bios is ok
        • DynaxSC
          by DynaxSC
          11-17-2023, 10:56 AM
        • TacticalFahrrad
          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
          by TacticalFahrrad
          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
          06-30-2025, 04:09 AM
        • vinaypundith
          Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
          by vinaypundith
          I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
          So, I'm looking for a BIOS dump for this machine - a 16MB one....
          08-03-2024, 12:32 PM
        • James Maxwell
          HP DM1-4000er Bios Dump needed
          by James Maxwell
          I badly need bios dump for HP DM1-4000er,
          Model: HP DM1-4000er
          Motherboard: DA0NM9MB6D0 REV.D
          Product: QJ490EA#ACB
          Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
          10-28-2024, 05:38 PM
        • mkdj
          by mkdj
          Dear all,
          10-19-2025, 04:41 AM
