HP G-62 AMD Flashed Bios Now SN is gone
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Hello, I have revived another mobo from a HP g62-A41SF AMD
    Now the pc boot's with this screen :
    Please Help
  • gcomputers
    • Apr 2013
    • 509
    • Albania
    Re: HP G-62 AMD Flashed Bios Now SN is gone
    It is normal after flashing bios . Try an utility NBDMIFIT. Bat , make usb bootable and with this utility you put your serial number etc.
    • passete
      Living=Sharing
      • Jun 2015
      • 487
      • France
      Can you please be more specific ?
      I have done the above, and I only see C:/ on the screen
      thanks
      • passete
        Living=Sharing
        • Jun 2015
        • 487
        • France
        Well, I dig a little bit, and here the result :
        Anyone else that can help please ?
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          do you have backup of old nonworking bios?
          Im Back... sort of...
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3622
            • slovakia
            u need this
            https://www.badcaps.net/forum/showpo...5&postcount=11
            • sopik78
              • Nov 2013
              • 518
              • Czech Republic
              or try this file first and you'll see if it works
              • gcomputers
                • Apr 2013
                • 509
                • Albania
                you need to command NBDMIFIT.BAT
                .BAT EXTENSION to take command.
                • passete
                  Living=Sharing
                  • Jun 2015
                  • 487
                  • France
                  Yes I do !
                  Can you help ?
                  • passete
                    Living=Sharing
                    • Jun 2015
                    • 487
                    • France
                    No change, same result !
                    Other tips ?
                    • passete
                      Living=Sharing
                      • Jun 2015
                      • 487
                      • France
                      Problem solved using HPBFO300 application
                      Thank you
                      • ala_borbe
                        aka Donald
                        • 1625
                        • Malta
                        i can do that manually, but you have already solved it
                        • passete
                          Living=Sharing
                          • Jun 2015
                          • 487
                          • France
                          I have a similar case with a HP CQ71, here : https://www.badcaps.net/forum/showth...851#post575851
                          I have the original corrupted bios backup, can you help me please ?
                          • mkdj
                            What should I do after having flashed a BIOS?
                            by mkdj
                            Dear all,
                            I did my first laptop repair related to a BIOS issue. Laptop is a Lenovo ThinkPad T480, and was not booting. With my brand new programmer, I did a back-up of the current not working BIOS, erased the BIOS chip, and flashed this dump: https://www.badcaps.net/forum/troubl...83#post3686683
                            Now the laptop works fine, I can access BIOS and boot on a USB drive. But I read stuff about DMI, and...
                            09-09-2025, 09:45 AM
                          • Loli Popu
                            DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
                            by Loli Popu
                            Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                            12-13-2024, 03:28 AM
                          • drux
                            Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
                            by drux
                            I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
                            Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
                            These models have AMI/Aptio BIOS.
                            Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
                            11-03-2024, 01:18 AM
                          • zenius
                            by zenius
                            12-08-2024, 06:13 AM
                          • lucaszmn
                            by lucaszmn
                            Problem:
                            Initial Findings:
                            • I concluded that the
                            08-12-2025, 03:01 PM
