BIOS dump svf152c219, eeprom programming question
  • Blacktek
    • Nov 2014
    • 250
    SO i got my first eeprom tool from ebay. ALso i have a sony laptop not booting up, it power on but then nothing after that. How do i use a bios dump to rewrite it on the bios chip?
    this is the devide i bought http://www.ebay.com/itm/CH341A-24-25...item2c9c8ed5e7
  • Life Goes On
    • May 2014
    • 264
    • Curacao
    Re: BIOS dump svf152c219, eeprom programming question
    You have to find the bios chip on your MOBO take it of and put in the adapter.
    The Night Drop Down, I Will Keep Try Until..., You Never know.
    Dushi Kòrsou, Nos Tei.
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      this may help you a little with the programmer stj member on here has posted some more recent software for this programer have a search im sure you will find the links etc.
      https://www.youtube.com/watch?v=L0ChYNwunUE
      • Blacktek
        • Nov 2014
        • 250
        ok thanks for the input guys.
        • Blacktek
          • Nov 2014
          • 250
          There are several files in a bios zip folder i got from the web, which one do i use?
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
          • haitham sharabati
            by haitham sharabati
            Hello engineers 😀,
            🔧 Device Info:
            - Model: HP 15-da2007ne
            - Product Number: 8XF55EA#ABV
            - Serial Number: CND0338P0D
            - CPU: Intel Celeron N4000
            💀 Problem:😅
            08-07-2025, 04:54 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • greelidd
            K6604J Vivobook RTX 4070 BIOS Dump Request
            by greelidd
            Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
            Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
            09-01-2025, 06:14 PM
