hi guys i need hp pavilion 11-n002tu bios file with orignal no display my programmer cant read that bios so plz i need this bios thanks in advance
Need Bios HP Pavilion 11-n002tu Urggently
Re: Need Bios HP Pavilion 11-n002tu Urggently
you need bios chip or bios dump file ?
if your programmor can't read this chip how can you flash this ?
if you think use the crisis recovry you can use hp web support, with a pendrive,
if you hdd is ok you can recover bios from it by presing Fn+B or Win+B to recover the corrupted bios, but i think if your bios is corrupted the laptop can return a blink code. -
backup old bios and try this
if your eprom 8mbAttached Filesif you find these attachements useful please consider making a small donation to the site
Im Back... sort of...
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by maanee11Hello Everyone,
I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
In the website, you can only see specs etc.
I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...1 Photo-
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
by iZakreHello everybody!
To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
The thing is that I had installed TeamViewer and could log into the computer... - Loading...
