ASUS k53sd rev 2.3 bios dump
  • hoaca388
    Badcaps
    • Jan 2022
    • 12441
    Re: ASUS k53sd rev 2.3 bios dump
    Originally posted by Skrillex1989
    Ist that right ?
    Try
    • Skrillex1989
      • May 2022
      • 16
      Not working 😑
      • Skrillex1989
        • May 2022
        • 16
        this is the broken orig. bios
        • hoaca388
          Badcaps
          • Jan 2022
          • 12441
          Try
          • Skrillex1989
            • May 2022
            • 16
            Nothing..
            I think the Chip ist dead
            I can find this Chip in ch341a Programm
            But after flash its not Matched
            • Zickko10
              • Sep 2021
              • 85
              • Nigeria
              #26
              K53E Bios Mainboard K53SD Rev 2.3
              Asus K53E
              Asus K53E-SX833v
              Mainboard no : K53SD Rev 2.3
              hi guys
              i have flash several bins from here still it will display sometimes and it will stop displaying
              here is the main old bin
              • danito
                • Jun 2016
                • 1259
                • Romania
                #27
                Asus K53E
                Asus K53E-SX833v
                hi guys
                Provide the serial number (or Service tag, SNID)
                • Zickko10
                  • Sep 2021
                  • 85
                  • Nigeria
                  #28
                  S/N : BAN0AS079800406
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12441
                    #29
                    K53E
                    • Zickko10
                      • Sep 2021
                      • 85
                      • Nigeria
                      #30
                      Originally posted by hoaca388
                      K53E
                      Thanks for the bin
                      Still the same issue
                      after I flash the bin it displaying after a day it stops displaying
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12441
                        #31
                        Thanks for the bin
                        So you don't have a problem with the bios, you have a hardware problem.
                        • Pablo~
                          • Jul 2024
                          • Argentina
                          #32
                          Thanks! it work for me, the oficial "A" site had someting wrong and my original chip was corrupted.
                          • mkdj
                            by mkdj
                            Dear all,
                            10-19-2025, 04:41 AM
                          • razor_amd
                            by razor_amd
                            12-15-2020, 07:07 PM
                          • pirati
                            by pirati
                            10-27-2025, 04:20 PM
                          • DynaxSC
                            by DynaxSC
                            06-14-2024, 03:49 PM
                          • Ahari
                            by Ahari
                            I...
                            08-13-2025, 06:12 AM
