Dell e6410 bios downgrade
  • indu
    • May 2015
    • 30
    • srilanka
    Re: Dell e6410 bios downgrade
    thanks
    • nimmay
      • Dec 2015
      • 82
      • Pakistan
      hi friendz
      i need urgent dell latitude E6410 bios dump bios location is U12 in intel
      NCL01 LA-5472P Rev:1.0 (A00)2010-01-18
      thankyou
      • swanand
        • Dec 2011
        • 51
        Thanks bro
        • techman1025
          • Jun 2014
          • 497
          Hi
          First thing you can't just use a donor bios it's dirty meaning me region once a computer boots it married to that computer the only way to use a donor is to either to rebuild it using Intel fit tool for that chipset or to merge the original file top half to either a donor or update bottom half so if it's 8mb cut the top half at 4mb and merge the other 4mb of bottom i have done it many times to remove password you need to replace both files bios &EC bin the only other way is to have the soft ware using service tag to gen master password 1d3b,1f5a, 1f66 6ff1, also the bios disk works if able to find your version on eBay hope this info helps
          Techman1025
          Techman1025
          • mitsuwou
            • Jul 2017
            • 3
            • Philippines
            Hi People any news on this?
            • mitsuwou
              • Jul 2017
              • 3
              • Philippines
              #26
              I got the same problem with my Dell E6410 after I tried updating the bios and laptop shuts down before it could finish my laptop is no longer showing anything on screen. laptop attempts to turn on with the power light lit and with black screen only
              • mitsuwou
                • Jul 2017
                • 3
                • Philippines
                #27
                Please advise
                • techman1025
                  • Jun 2014
                  • 497
                  You either killed the Bio chip or firmware is total corrupted try a different donor firmware just to get it to start again after that upload it here and i will put a clean me region on it then we will need the other chip on board and also replace firmware kbc .
                  external monitor showing anything ? caps lights come on when you a temp to power laptop up. do you have RSMRST3.3V & S5 3.3v at KBC?
                  Techman1025
                  • WEC777
                    • Aug 2017
                    • Pakistan
                    #29
                    I've got a Dell Latitude E6410 (Intel video) with BIOS A15 and a [SERVICETAG]-1F5A message with the bios admin lock. USB booting is turned off (not even available under F12 boot), so I'm guessing I'll have to burn a CD/DVD of Hiren's to get it downgraded to version A14, since when I try to run E6410A14 /forceit command in Windows, it asks me for the bios (not Windows) admin password. I've tried bios versions back to A09 and they all give me the same result. I also noticed that there are a couple of peeps on eBay who claim to be able to give a master unlock code for the 1F5A lock for my E6410. Any additional thoughts or info would be appreciated.
                    • techman1025
                      • Jun 2014
                      • 497
                      Hi first yes there is a hash tool for the 15FA and very few people have it and it works . I have it for older models also there are bio disks sold on eBay that let you clear password and edit service tags when you do a system change to match the unit the only other way to clear it is to replace both bio's file and ec bin at the same time and only way this is done is with donor files so what this means is you would need to either merge your original me region into the donor file for the bio's only or rebuild a new me region using a clean never used one and rebuild it to match you laptop specs like i5 and chipset used and so on all doable . Hope this give you your answer .
                      Techman1025
                      • shaon_kof
                        • Feb 2014
                        • 41
                        • Bangladesh
                        #31
                        Thanks @wallyoz7
                        • mohammed mohan
                          • Nov 2017
                          • 210
                          • F12
                          #32
                          Thank you
                          Mohammed Mohan
                          • cybernova
                            • May 2015
                            • 35
                            • IRAN
                            #33
                            Thanks alot
                            • Jokerx84
                              • Sep 2017
                              • 52
                              • Hungary
                              #34
                              Hi! After upgrading Bios to A09-A17, it turns on, but the screen is black!
                              I've tried all the dumps, but nothing has changed!
                              Can somebody help me?
                              • peste
                                • Dec 2016
                                • 13924
                                • ROMANIA
                                #35
                                try..
                                • Jokerx84
                                  • Sep 2017
                                  • 52
                                  • Hungary
                                  #36
                                  Originally posted by peste
                                  try..
                                  thanks but unfortunately it doesn't work
                                  • peste
                                    • Dec 2016
                                    • 13924
                                    • ROMANIA
                                    #37
                                    try this for the 4MB one too.
                                    • Jokerx84
                                      • Sep 2017
                                      • 52
                                      • Hungary
                                      #38
                                      unfortunately not with that either
                                        • 22293
                                        Try this bios, flash both .
                                        • Marc97
                                          • Jan 2016
                                          • 189
                                          • Phillipines
                                          #40
                                          file tested good,,,, thank you
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                          • Sathsul
                                            Dell Latitude 5431 issues with dumping bios
                                            by Sathsul
                                            So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                            The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                            However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                            10-28-2025, 07:49 AM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                            11-02-2024, 04:19 AM
                                          • YOUCEF4787
                                            Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
                                            by YOUCEF4787
                                            I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
                                            Initial Problem:
                                            The laptop was completely dead, no signs of life, no power LED.
                                            Action Taken:
                                            I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
                                            Current Situation & The Main Issue:
                                            The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
                                            09-21-2025, 12:19 PM
                                          • TripTop
                                            Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                                            by TripTop
                                            Hi
                                            i have dell latitude E7270 with following symptoms:
                                            - takes long time to restart.
                                            - sometimes powers on and then off
                                            - sometimes while working it just dies,
                                            From googling online bios clean could possible resolve this?
                                            i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                                            As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                                            I reinstall...
                                            09-09-2024, 02:05 PM
