How to flash a Dell Bios
  • khilborn
    • May 2015
    • 6
    I've got a Dell Latitude E6420 that I want to flash so that I unlock a few things. I got the .BIN files from here: https://www.badcaps.net/forum/showthread.php?t=41818
    With those, how can I flash the bios? I'm not familiar with a tool that will allow me to flash it easily with bin files since the BIOS is Intel I believe.
    A guide would be awesome
  • Life Goes On
    • May 2014
    • 264
    • Curacao
    Re: How to flash a Dell Bios
    You wil need a programmer to do that, like Mini Pro or EZP 2010 of something similar.
    The Night Drop Down, I Will Keep Try Until..., You Never know.
    Dushi Kòrsou, Nos Tei.
    • khilborn
      • May 2015
      • 6
      There's not a programmatic way to flash the bios like a bios utility, or something similar to awdflash or uniflash for Intel?
        • 31214
        yes, maybe winphlash
        https://www.wimsbios.com/phoenixflasher.jsp
        • khilborn
          • May 2015
          • 6
          I don't think Phoenix likes bin files or intel main boards.
          When I try to do a backup it says: "Corrupted interface descriptors in the new BIOS file."
          "Part Table Signature not found in the interface"
            • 31214
            it works with bin files - i'v done it.
            not sure about the Intel bit.
            it could be something about the bios.
            i'll go dig around.
            • khilborn
              • May 2015
              • 6
              Figured I'd give this post a bump before I go and start building USB boot disks and trying out a few things
              • khilborn
                • May 2015
                • 6
                One more bump since I haven't really gotten anywhere in the last couple of weeks
                • Mojtabasultani
                  Soulless
                  • Jan 2020
                  • 4
                  • Afghanistan
                  Originally posted by stj
                  Thank you very much sir.
                  • mrrubik
                    Dell Optiplex 7010 micro bad BIOS flash?
                    by mrrubik
                    Hi folks,
                    I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                    After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                    Steps I took:
                    1. Read BIOS with CH341a, verified hash twice
                    2. Patched
                    12-23-2024, 04:11 PM
                  • Vesko356
                    by Vesko356
                    08-11-2023, 03:27 AM
                  • mikeybass
                    by mikeybass
                    04-23-2025, 04:30 PM
                  • YOUCEF4787
                    Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
                    by YOUCEF4787
                    I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
                    Initial Problem:
                    The laptop was completely dead, no signs of life, no power LED.
                    Action Taken:
                    I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
                    Current Situation & The Main Issue:
                    The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
                    09-21-2025, 12:19 PM
                  • Akhlz001
                    by Akhlz001
                    09-20-2025, 07:15 PM
