Macbook A1342 (820-2883-A) bios dump
  • dycc
    Vision
    • Nov 2011
    • 625
    • Côte d'Ivoire
    hello guys
    someone can share this bios dump A1342 (820-2883-A)
    thanks
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Macbook A1342 (820-2883-A)
    it is hard, if not impossible to mach efi bios on mac
    if you are removing password, its easier to read bios and discard password... pm me if you need help or post dump here
    i found few dumps here, you can try, but ALWAYS BACKUP your org bios
    Code:
    http://notebook1.ru/forma1/viewtopic.php?f=352&t=49555&hilit=a1342
    Im Back... sort of...
    • dycc
      Vision
      • Nov 2011
      • 625
      • Côte d'Ivoire
      thanks already try bios from this link but unsuccessful
      yes i am trying to remove password
      • rookieme
        • Oct 2014
        • 396
        • Greece
        I'm not sure if this will do for you but give it a try.
        Remove one out of two RAM or add one if you have only one just to change the amount.
        Boot and make NVRAM reset by holding 'command', 'option', 'P' and 'R' all together.
        • degutji
          • Dec 2012
          • 173
          • Indonesia
          I have one at home, but can you tell me the EMC # ?
          • dycc
            Vision
            • Nov 2011
            • 625
            • Côte d'Ivoire
            upload yours if you want to help . what do you mean by EMC????
            • degutji
              • Dec 2012
              • 173
              • Indonesia
              Of course, I will try to help because we are supposed to help each other. that is the purpose of this forum
              Read this
              http://www.everymac.com/mac-identifi...ification.html
              • dycc
                Vision
                • Nov 2011
                • 625
                • Côte d'Ivoire
                thanks for help but yours is 820-2567 mine is 820-2883-A.
                • degutji
                  • Dec 2012
                  • 173
                  • Indonesia
                  Oh..sorry about that, upload your original bios first for learning purpose, who knows we can bypass it
                  • ala_borbe
                    aka Donald
                    • 1625
                    • Malta
                    @dycc have you solved this?
                    would you be so kind to post your dump here pls, or send me a pm?
                    • dycc
                      Vision
                      • Nov 2011
                      • 625
                      • Côte d'Ivoire
                      here mine
                      • dycc
                        Vision
                        • Nov 2011
                        • 625
                        • Côte d'Ivoire
                        Sorry but i follow your link and i don't find $SVS in my dump .
                        sorry again for late reply.
                        • ala_borbe
                          aka Donald
                          • 1625
                          • Malta
                          many firmwares can be found here if you know EMC code
                          Code:
                          https://ghostlyhaks.com/downloads/2014-07-25-06-43-32/efi-firmware
                          this is an older version, don't have $SVS trick avilable
                          or try this dump
                          • dycc
                            Vision
                            • Nov 2011
                            • 625
                            • Côte d'Ivoire
                            will try it . EMC=2350
                            • dycc
                              Vision
                              • Nov 2011
                              • 625
                              • Côte d'Ivoire
                              unfortunately none of them work .
                              • dycc
                                Vision
                                • Nov 2011
                                • 625
                                • Côte d'Ivoire
                                Sorry guys the original bios is working well . it was a problem with hard drive . tanks anyway
                                • degutji
                                  • Dec 2012
                                  • 173
                                  • Indonesia
                                  Glad to hear that sir, maybe that's way no $SVS in your dump
                                  • dycc
                                    Vision
                                    • Nov 2011
                                    • 625
                                    • Côte d'Ivoire
                                    perhaps i have to set password and check if $svs trick is available
                                    thanks degutji and ala_borbe
                                    • Habble7
                                      by Habble7
                                      Suspected Cause:
                                      Troubleshooting Attempts:
                                      05-22-2025, 07:28 AM
                                    • DynaxSC
                                      by DynaxSC
                                      11-17-2023, 10:56 AM
                                    • grimacelord
                                      Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                      by grimacelord
                                      This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                      Motherboard model number: DA0PAMB46A1 REV: A
                                      Secondary motherboard model number: 0PAB
                                      SKU: 685K4UA
                                      Serial number is: 5CD3223BJP
                                      Recently reflashed this laptop with latest BIOS and once...
                                      05-07-2024, 08:06 AM
                                    • DynaxSC
                                      Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                                      by DynaxSC
                                      I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                                      It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                                      I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                                      11-06-2022, 05:22 PM
                                    • TacticalFahrrad
                                      [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                      by TacticalFahrrad
                                      I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                      06-30-2025, 04:09 AM
