hp dv6410eo no wlan whitelist bios needed
  • reaper57
    • Sep 2014
    • 216
    • Norway
    Hi, I have a hp dv6410eo that I can't seem to get the wifi to work under windows 7. I've tried all sorts of drivers, but it just gives an exclamation mark and a no internet access label. I have a box full of wifi adapters but they all cause the laptop to give me a "104 unsupported wireless network device detected".
    So anyway, can someone link me to a bios with a removed wireless device whitelist? I know that there are tools that allow bios modification, but I can't seem to find one compatible with this laptop, plus I'm not that good at programming.
    If you need any other information I'll be glad to provide it!
    Thanks in advance!
    Keyboard not detected, press F1 to continue...
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3622
    • slovakia
    Re: hp dv6410eo no wlan whitelist bios needed
    check original bios file name from hp and get whitelisted bios from here
    https://www.bios-mods.com/BIOS/index...=Whitelists%2F
    • reaper57
      • Sep 2014
      • 216
      • Norway
      Thanks, I'll check that ASAP!
      UPDATE: I found a file that matches the name of the original file, I'll give it a go later on today.
      • reaper57
        • Sep 2014
        • 216
        • Norway
        I tried it and it gives me a "BIOS.WPH can not be found" error. Any ideas?
        • reaper57
          • Sep 2014
          • 216
          • Norway
          Fixed it! And it no longer gives me an error about an unsupported network adapter. For anyone that had the same problem, copy the "30BBF2E.WPH" into the "SWinFlash" folder and rename it to "BIOS.WPH"!
          Thank you to ktmmotocross for the link and also thanks to whoever created it (I think it was someone called Camiloml) and uploaded it.
          • lucaszmn
            by lucaszmn
            Problem:
            Initial Findings:
            • I concluded that the
            08-12-2025, 03:01 PM
          • tlindi
            Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
            by tlindi
            Sublect line continuation: ... Jaguar IDS PC aka Panasonic
            >Read BIOS guides, methods, resources and tools
            Ack
            >Try the method at BIOS guides, methods, resources and tools before requesting help
            Ack
            >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
            python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
            01-30-2025, 04:26 AM
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
          • helpmepleasethanks
            Thinkpad T440P bios repair after WIFI whitelist mod
            by helpmepleasethanks
            As per the the rules, here are the specifications of my laptop :
            • Make and model number : Thinkpad T440P
            • Serial number (S/N) : PB-03A7V7
            • Model type - Model (MTM) : 20AW-S2N800
            • Bios version : 2.50 (not 100% sure, that's what I remember)
            Here is the problem, and the events leading to it :
            1. Upgrade screen, keyboard, trackpad, RAM and CPU
            2. Reboot and use the laptop for a bit : everything is working fine
            3. Shutdown (no power) and upgrade WIFI with unsupported chip (AX210)
            4. Boot up the device : bios warning, as expected
            5. Shutdown the device again (no power)
            6. Connect the 8-pin clip of a CH341a
            01-09-2025, 12:09 PM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
