lenovo g500 bios la-9632p
Re: lenovo g500 bios la-9632p
HI
Same laptop was repaired and returned,again came after 1 month ,now problem is stays on for 5-7 seconds than off .3.3 ALW&5 ALW Fine. after connecting adapter in U4 intel BGA (SLJ8E )starts heating .no other power found at any coils.where to start from or intel gone.
ThankComment
PCH should not heat up when the computer is off. It should get warm when the computer is on. Most likely the PCH is bad.
Make sure the computer is actually off when the PCH is heating up. Check the resistance to ground on the 3.3VALW line and on the PCH core voltage (+V1.05S_VCCP).
Make sure the PCH core voltage (+V1.05S_VCCP) is *absent* when the computer is *off*, and *present* when the computer is *on*.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
Thanks for reply ,PCH should not heat up when the computer is off. It should get warm when the computer is on. Most likely the PCH is bad.
Problem solved,replaced pchComment
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by grimacelordHello there.
History:
I searched for this error online and discovered...-
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
by mkdjDear all,
I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
Here the steps I have taken to fix the laptop:
- downloaded latest BIOS from Lenovo Website... - Loading...
