elitebook 2570p bios dump
  • Djosla
    • Dec 2012
    • 246
    • Montenegro
    I need a bios dump for elitebook 2570p with i5 cpu
    somebody can help me with this?
    it`s 16mb dump...
  • techman1025
    • Jun 2014
    • 497
    Re: elitebook 2570p bios dump
    Hi
    If you need dmi info fix upload original file.
    techman1025
    • techman1025
      • Jun 2014
      • 497
      Here
      the bottom half of you file is blank.. let me know how it go's
      techman1025
      • amukd
        • Mar 2016
        • 3
        • pakistan
        please give me hp elitebook 2570p bios dump 16MB
        • whitejohnny71
          • Mar 2010
          • 26
          Hi, so you know how to add dmi info to an HP 2570p bios dump - can you explain the process for us?
          Some of the units we buy come bios locked, so I usually download a dump and then use the nbdmifit and windmifit tools to enter the info. This doesn't always work - sometimes the tool thinks the bios is locked even though the post screen says its in manufacturing mode which means its unlocked, right?
          So I'd like to take a dump, add the dmi info, then flash it. So, if you can help I appreciate it!
          • rioreno
            • Feb 2009
            • 540
            • Indonesia
            1. You CANNOT add dmi info to blank dump with nbdmifit or wndmifit BEFORE flash...
            2. BUT, if u download a newdump file with BLANK dmiinfo, and flash it, then you will facing Manufacturing Mode, thats mean your notebook has unlocked,so you can enter winOS
            3. Wndmifit can mpm unlocking,but sometimes some info cannot be filling by this programs, you need another tools : biosconfigutility
            4. So you can use BIOSCONFIGUTILITY to fill FULL INFO of your DMI.
            • whitejohnny71
              • Mar 2010
              • 26
              I meant with a Hex editor like HxD
              Ok, so the blank dmi info triggers manufacturing mode?
              Hmm, wndmifit probably calls BIOSCONFIGUTILITY. I haven't been able to unlock anything with wndmifit, only lock...
              So what I am getting at is - How do I make a blank dump from my units dump using a hex editor? Because that way I can preserve or update ME regions, etc...
              With other brands I dump with a ch341 type programmer, then use HxD to edit as necessary, then flash it back...
              • whitejohnny71
                • Mar 2010
                • 26
                Originally posted by techman1025
                Hi
                techman1025
                This is the post I'm referring to - Techman, are you blanking the dmi info or replacing with new dmi?
                And how do i do it lol? How do I blank the DMI info? Just hex in 00s? or...
                Id like to know the offsets if anyone has worked them out, or text search strings to find the dmi info in the dump. I've seen the system configration IDs (usually look like A1009D11 or A1002C22 etc) in dumps before...
                • rioreno
                  • Feb 2009
                  • 540
                  • Indonesia
                  You can using hxd and UEFITOOL
                  Yes blank dmiinfo will trigger manufacturing mode..
                  How to make a blank dump , check my posting :
                  https://www.badcaps.net/forum/showpo...19&postcount=6
                  • whitejohnny71
                    • Mar 2010
                    • 26
                    Sweet, headed there now... Thank you for your help!
                    • techman1025
                      • Jun 2014
                      • 497
                      Hi
                      Whitejohnny 71 That's the way to do it other way is to use the correct DMI TOOL version.
                      Techman1025
                      • solomost
                        • Sep 2021
                        • 30
                        • agadir
                        Hi
                        can you fix bios dump for elitebook 2570p
                        motherboard number: ML1 94V-0 E253117​
                        S/N : CNU333B8Q9
                        thank you
                        • peste
                          • Dec 2016
                          • 12254
                          • ROMANIA
                          Originally posted by solomost
                          Hi
                          S/N : CNU333B8Q9
                          thank you
                          try.. 8.1.71.3608_5MB_PRD_RGN.rar
                          • Habble7
                            by Habble7
                            Suspected Cause:
                            Troubleshooting Attempts:
                            05-22-2025, 07:28 AM
                          • DynaxSC
                            by DynaxSC
                            11-17-2023, 10:56 AM
                            HP EliteBook 2570p Notebook 2000 Specification for Upgrade or Repair
                            This specification for the HP EliteBook 2570p Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 2570p boardview and 2570p schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP EliteBook 2570p...
                            09-06-2024, 05:27 AM
                          • Guest
                            Elitebook 850 G5 BIOS bricked
                            by Guest
                            I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                            I assume the BIOS update failed, so I searched for the BIOS chip.
                            I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                            However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                            Can the corrupted...
                            03-24-2025, 01:21 AM
