ASUS N55SF problem with BIOS
  • kyzya30
    • Feb 2015
    • Ukraine
    Describe problem. Yesterday I decided to reinstall Windows, have installed SSD I decided to do a secure erase for him, I booted from USB which have Parted magic, reset took place without any problems. After the reboot, what is wrong with bios, after the POST message appears that that there is no operating system - displays a black screen, and then I put the stick and install win8, at the stage of the first reboot it did not take place as it should, and as a long time. After windows installation is complete, saw that now is not working properly restart, shutdown does not work, and also the sleep mode. Shutdown and sleep mode are of the form - its looks like the monitor is off, the electronics too, but the motherboard is working and cooler too. I reflash the BIOS latest BIOS available on the site asus .207 few times, but it did not help.
    Also important will still announce that two weeks ago, I flash bios from N55SL, as a result there were signs are the same as I described above that not working - shutdown, restart and sleep. Seeing these things I flash back the original bios of my model n55sf, and everything was normal work (until yesterday).
    Sometimes when the laptop does not turn on, burn 2 lights - power and capslock, heard how the cooler and through somewhere 30 seconds notebook is off. Have to turn on it 1-2 times until it starts.
    This problem is hardware since I tried it with other operating systems do the same operation(shutdown, reboot,sleep) - Win7 Win8 Linux, the result remained the same.
  • kyzya30
    • Feb 2015
    • Ukraine
    Re: ASUS N55SF problem with BIOS
    Nobody help, but...
    Solution of this problem - is reset CMOS.
    • dikmen
      • Apr 2015
      • 49
      • TURKIYE
      hi
      asus n55sf bios dump
      please
      • cacla
        • Apr 2015
        • 444
        Try this one
        • talat
          • Oct 2017
          • 15
          • pl
          gooooooooood
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • grimacelord
            by grimacelord
            07-10-2025, 02:52 PM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
          • lrouw84
            Asus vivobook s510ua bios changed to x510un
            by lrouw84
            Hi there,
            I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
            I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
            01-28-2023, 01:31 PM
