bios dump for toshiba satelite P200D-12O
  • rookieme
    • Oct 2014
    • 399
    • Greece
    The model is toshiba satelite P200D-12O
    motherboard is LA-3831P
    It has power but doesn't power on so I'll try reprogramming the bios first.
    anyone has it?
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: bios dump for toshiba satelite P200D-12O
    if you can read your bios and ec i can give you anew one
    i acquired bios, but i need dump to see where to split it
    Im Back... sort of...
    • techman1025
      • Jun 2014
      • 497
      Hi
      First when wanting a bio's you always need to upload the original it's needed to compare with update ..but i'm sure in your case it just a bad N/B ATI-RS690MC heat it to 100C if laptop come alive you need to replace ...the chip it self is bad nothing to do with solder balls here is schematic if needed
      Techman1025
      • rookieme
        • Oct 2014
        • 399
        • Greece
        Luckily I have backuped the old bios [attached file]
        I tried to reprogram the bios but I'm not sure if I found the correct one.
        Toshiba doesn't host bios for vintage notebooks - too bad, HP does.
        Usually with AMD CPUs the problem is the northbridge [I do reballing].
        This time I wasn't sure as it doesn't fire up - usually they do.
        I'll try reballing and reflash old bios.
        Will post the results.
        • rookieme
          • Oct 2014
          • 399
          • Greece
          The credits go to you Techman1025.
          After reballing it booted normaly.
          I'll try how will last and then consider replacing the chip.
          As the chip is worn out can you tell me the model is 216LQA6AVA12FG?
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            here is 1.7 version, maybe someone else needs it
            • erhanabdullah
              • Nov 2015
              • 24
              • turkey
              thanks
              • LP_tekh
                • Oct 2015
                • 95
                • Laos
                Thank you Donald!
                • atlant321
                  • Feb 2016
                  • Moskov
                  Originally posted by erhanabdullah
                  thanks
                  thanks
                  after replacement of the battery charge has become full
                  5200mAh Battery for Toshiba PA3536U-1BRS
                  • atlant321
                    • Feb 2016
                    • Moskov
                    Originally posted by techman1025
                    Hi
                    Techman1025
                    thanks
                    • fayal
                      • Jan 2015
                      • 14
                      hi ala_borbe
                      thanks my freind.
                      • Ahari
                        by Ahari
                        I...
                        08-13-2025, 06:12 AM
                      • Habble7
                        by Habble7
                        Suspected Cause:
                        Troubleshooting Attempts:
                        05-22-2025, 07:28 AM
                      • haitham sharabati
                        [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                        by haitham sharabati
                        Hello engineers 😀,
                        I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                        🔧 Device Info:
                        - Model: HP 15-da2007ne
                        - Product Number: 8XF55EA#ABV
                        - Serial Number: CND0338P0D
                        - CPU: Intel Celeron N4000
                        - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                        💀 Problem:😅
                        - Device shows “Administrator Password”...
                        08-07-2025, 04:54 AM
                      • DProf.
                        TOSHIBA DYNABOOK T55/AB, PT55ABP-BJA2 BIOS DUMP
                        by DProf.
                        High great minds, please i need bios dump for this system .or help to REMOVE the PASSWORD in my original dump
                        Toshiba Dynabook T55/AB, PT55ABP-BJA2
                        MODEL NAME. Satellite L50-D series
                        P[ART NO PS57MN-00600R
                        Attached is my original bios dump ADMIN. PASSWORD LOCKED. Thank you in advance....
                        09-26-2024, 04:30 AM
                      • Citymin
                        by Citymin
                        S/N : 5RNK9FFT70...
                        08-05-2025, 05:12 AM
