acer v5-123 bios dump
  • rickybucalan
    • May 2013
    • 322
    • philippines
    hello guys...
    i just need bios dump for my acer V5-123 model..
    thanks in advance....
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: acer v5-123 bios dump
    backup your old bios and use this
    DAOZHLMB6D0 REV: D
    if board has ec, dump and post here, i will make ec also
    Im Back... sort of...
    • rickybucalan
      • May 2013
      • 322
      • philippines
      DAOZHLMB6D0 REV: D
      tnx buddy. but it doesn't fix my problem.
      it just post back light on with underline cursor at top left corner of screen. with no respond.
      what did you think about this problem?
      • rickybucalan
        • May 2013
        • 322
        • philippines
        any ideas guys.
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          does it show acer logo?
          if yes, take hard drive and scan it for bad sectors in another pc, or put another working hdd and try to install windows
          • rickybucalan
            • May 2013
            • 322
            • philippines
            nothing at all. just light the screen then stackup
            • Sukhvinder
              • Oct 2014
              • 4
              • India
              take out the lvds cable and clean both connectors, check if the cable is okay reinsert it
              • abecedad
                • Mar 2014
                • 7
                • Colombia
                Thank you very much, it worked for me
                • nova100
                  • Feb 2017
                  • 35
                  • Egypt
                  thank you
                  • String2016
                    • Nov 2015
                    • 2234
                    • philippines
                    thanks
                    • boussaa islem
                      • Nov 2018
                      • 30
                      • ALGRIA
                      black screen
                      laptop acer acer daozhlmb 6d0 rev
                      • odem
                        • Mar 2019
                        • Egypt
                        How to flash this bin file ?
                        • Ghost18_07
                          Zakaria
                          • Mar 2018
                          • 75
                          • Algeria
                          Use a programmer like RT809 and so on
                          • Ghost18_07
                            Zakaria
                            • Mar 2018
                            • 75
                            • Algeria
                            Originally posted by boussaa islem
                            black screen
                            Is it turning off after a while ?
                            • djharold
                              • Aug 2015
                              • 241
                              • COLOMBIA
                              DAOZHLMB6D0 REV: D
                              thank you
                              • James194zt
                                Acer Nitro 50-640E Corrupted BIOS Dump
                                by James194zt
                                My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
                                All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
                                04-28-2025, 03:29 PM
                              • Habble7
                                by Habble7
                                Suspected Cause:
                                Troubleshooting Attempts:
                                05-22-2025, 07:28 AM
                              • ZOrd_Z
                                Acer Predator P03-650 bios DUMP.
                                by ZOrd_Z
                                I need a bios dump to a Acer Predator P03-650 board.
                                Or to convert the .CAP file o a file to flash.
                                Thank's......
                                10-29-2024, 12:06 PM
                              • DynaxSC
                                by DynaxSC
                                11-17-2023, 10:56 AM
                              • matrix37
                                Acer Aspire 3 A315-58G-537Z N20C5 BİOS DUMP
                                by matrix37
                                Hello, good luck. As a result of uploading a file to my Acer laptop, the laptop won't start at all. When I try the bios files of different motherboards, the computer does not turn on and the screen does not show. I am adding my own original bios file. If anyone has a good bios file, I would appreciate it if you could help me.
                                computer model no: Acer Aspire 3 A315-58G-537Z
                                motherboard number::FH5AT LA-K092P Rev 2.0 2021-10-18
                                I'm waiting for your help.
                                Badcaps Electronics Repair Forum & Schematic Search
                                02-01-2024, 09:10 AM
