Need K55A Bios Dump
  • borisyoel
    • Aug 2015
    • usa
    Re: Need K55A Bios Dump
    please i have a error CRC in winrar trying to descompress this file,please you could send methis file asus new.zip to my email borisyoel@yahoo.es
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      Code:
      http://www.rarlab.com/download.htm
      Im Back... sort of...
      • gilmario32
        • Nov 2015
        • bahia
        muito bom amigo
        • davidmonas
          • Apr 2016
          • Spain
          I have a problem... i hope you can help me. I have a k55a motherboard too and it has an incorrect BIOS rom. I try to upgrade, with afudos program, BIOS rom you upload some months ago but program doesn't let me because file size of my BIOS ROM is not the same
          Can you help me?
          Thanks a lot from Spain!
          • passete
            Living=Sharing
            • Jun 2015
            • 487
            • France
            Can you help me?
            This is because those files are to be used wit a programmer, and not from Windows.
            if you can run afudos, i assume that your pc is working, in this case download the correct bios for your model from asus website and flash from there.
            Or, desolder bios chip from mobo, put in bios programmer, erase and flash, then solder it back to mobo.
            • kronnos
              • Dec 2015
              • 9
              #26
              works man , a lot of 10x
              • yeah
                • Jul 2016
                • España
                #27
                I have the same problem that Simpletek, when I programed the BIOS with the x55a.zip and k55vd.zip files I had the same problem of the fan at the maximun speed all time.
                When I programed with the "asus new.zip" file the fan runs correctly, but the laptop takes about 20 seconds to start since you hit the button, which did not happen before.
                My laptop is the A55A and the Motherboard is K55VD rev 3.1 integrated video.
                Any idea?
                • nervero
                  • Jan 2015
                  • 30
                  • NL
                  #28
                  [QUOTE=ala_borbe;528372] Thanks man it works
                  • Pascal Komlassan
                    • Jan 2017
                    • 809
                    • TOGO
                    #29
                    Originally posted by ala_borbe
                    both should work... any way, backup your old bios
                    thanks bro
                    • rediii
                      h???, spurrrn
                      • Mar 2018
                      • 501
                      • somewhere in europe
                      #30
                      ok, this one?
                      Thank you man, worked perfectly!
                      • sc-tamra
                        • Apr 2014
                        • 6
                        • israel
                        #31
                        thank you very much
                        100% working bios
                        • io00
                          • May 2019
                          • 10
                          • Italy
                          #32
                          ok, this one?
                          Flashed "asus new" on an Asus X55A. Everything went good.
                          Thanks!
                          Of course, now the bios believes that it is a k55, but it's ok. I think they are essentially the same machine, just with an unlocked chipset on the k55.
                          If someone, like me, is using a cheap CH341A programmer with clips to flash, be aware that you might want to cover with electrical tape pin 8 of the bios chip to ensure that it is properly recognized by the program (it has to do with the voltage supply to the chip)
                          • io00
                            • May 2019
                            • 10
                            • Italy
                            #33
                            Thanks!
                            Well, maybe I spoke too soon... i have no longer access to the usb ports... any suggestion for my x55a?
                            • io00
                              • May 2019
                              • 10
                              • Italy
                              #34
                              if someone else finds himself in the same situation, try to search "Asus F55A MB X55A REV-2.1" on google to retrieve the correct .bin file for the laptop. Then flash, update to version 417 using the cap file from asus and save a working dump to keep in case of further problems
                              • linuss437
                                • May 2015
                                • 12
                                • la spezia
                                #35
                                grazie a tutti bios ok funziona su asus x55a con mainboard x55a rev 2.0 un saluto al forum
                                • fikonaz
                                  • Mar 2017
                                  • 38
                                  • turkey
                                  #36
                                  ok, this one?
                                  thanks BRO
                                  • SirangKap
                                    • Feb 2020
                                    • 29
                                    • Philippines
                                    #37
                                    Re: Need K55A Bios Dump Repair
                                    hello.. can anybody here help me fix my laptop BIOS?
                                    i will attached here my original bios which i copied from the chip in the motherboard. My motherboard problem is that the fan spins fast then slow then fast then slow. It's doing these for a few minutes then it will restart again and again doing the same thing after restart.
                                    • qayyum786
                                      • Aug 2018
                                      • 1959
                                      • INDIA
                                      #38
                                      Originally posted by sirangkap
                                      hello.. Can anybody here help me fix my laptop bios?
                                      I will attached here my original bios which i copied from the chip in the motherboard. My motherboard problem is that the fan spins fast then slow then fast then slow. It's doing these for a few minutes then it will restart again and again doing the same thing after restart.
                                      try
                                      • SirangKap
                                        • Feb 2020
                                        • 29
                                        • Philippines
                                        #39
                                        Originally posted by qayyum786
                                        try
                                        Thank you so much sir for quick response. I will try it and let you know if it will fix the problem.
                                        Update;
                                        After programming it to the bios chip,now the display is blank. Then after a minute the laptop shuts down. And the fan spins just like before. Any other solution sir?
                                        • peste
                                          • 13588
                                          • ROMANIA
                                          #40
                                          the posted bios is longer..be careful when writing and reading..try..if it doesn't work, post pictures with the stickers on the motherboard (white or green) ..
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • mkdj
                                            by mkdj
                                            Dear all,
                                            10-19-2025, 04:41 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • haitham sharabati
                                            by haitham sharabati
                                            Hello engineers 😀,
                                            🔧 Device Info:
                                            - Model: HP 15-da2007ne
                                            - Product Number: 8XF55EA#ABV
                                            - Serial Number: CND0338P0D
                                            - CPU: Intel Celeron N4000
                                            💀 Problem:😅
                                            08-07-2025, 04:54 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
