BIOS DUMP FOR ASUS K50IJ , urgent !
  • highpulse
    i hate HP
    • May 2013
    • 1489
    • portugal
    I there , guys i need this bios if someone can share it , i apreciate it .
    thk in advance
  • nazrul145
    • Jan 2014
    • 333
    • BD
    Re: BIOS DUMP FOR ASUS K50IJ , urgent !
    Try it
    • bayuseto
      • Mar 2013
      • 13
      • Indonesia
      Originally posted by nazrul145
      Try it
      thank you
      • sopik78
        • Nov 2013
        • 517
        • Czech Republic
        another one..
        • fyaagoub
          • 269
          • maroc
          • xeed
            • Mar 2016
            • 26
            • syria
            thanks
            • GREAT_MERA
              • Jul 2021
              • 14
              • sri lanka
              thanks
              • luisfm2
                • Jan 2015
                • 51
                • Portugal
                Thanks.
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • DynaxSC
                  by DynaxSC
                  06-14-2024, 03:49 PM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • Anchar777
                  ASUS P1412CE need BIOS DUMP
                  by Anchar777
                  Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                  06-26-2025, 03:39 AM
