samsung 540u i5 can't go in bios setup.
  • rickybucalan
    • May 2013
    • 322
    • philippines
    happy new years guys....
    i just have a question for this laptop samsung 540u i5 ultrabook windows 8 it just crash after windows update according to client.
    when trying to windows recovery button (F4) it does't work.
    trying to go bios setup cant do either. i press f2, del, f10,
    what do you thinks is wrong?
  • Francisco.s
    • 686
    • Spain
    Re: samsung 540u i5 can't go in bios setup.
    Try with an external keyboard.
    • lezsimply
      The Wanderer
      • 645
      • Philippines
      have you tried removing hard drive?
      • lefos
        • Nov 2013
        • 321
        • Greece
        Does it have any key, like assist, in order to get to recovery options? Try to power the laptop on from that button. Newer models due to UEFI require this. It won't allow you to press any key during the windows start up.
        • diif
          • Feb 2014
          • 6978
          • England
          You can't enter the BIOS/UEFI on a Windows 8 machine until has been shut down properly, it's just in sleep/hibernation mode otherwise.
          The shift key needs pressing whilst you click shutdown. Then the BIOS/UEFI can be entered.
          • rickybucalan
            • May 2013
            • 322
            • philippines
            sorry guys i didn't fix it. the client really need asap so i give it back. but i really appreciate your help. tnx.
            • tushar ahamed
              • Mar 2013
              • 6
              • bangladesh
              any one have samsung 540u3c lotus13-tsp bios dump.. I cannot enter the bios ri8 now.. any one help ..thanks
              • highpulse
                i hate HP
                • May 2013
                • 1488
                • portugal
                having this issue and also needing a dump
                • ghojariya abdul
                  • Jul 2014
                  • 39
                  • india
                  http://mobile.badcaps.net/forum/showthread.php?t=53669
                  try this.
                  • macabook
                    by macabook
                    🧩 Initial Issue
                    07-24-2025, 02:17 PM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • Vesko356
                    by Vesko356
                    08-11-2023, 03:27 AM
                    09-07-2024, 05:50 AM
                  • TJ65
                    Samsung Galaxy Tabpro S BIOS and Micom Version doesn't match
                    by TJ65
                    i made out of two broken Samsung Galaxy Tabpro S one that works partially.
                    The one Mainboard had a broken screen output but working hdmi (usb c adapter) output and the other didnt start at all.
                    I switch the bios chips and now the tablet starts but very very slow and it takes some trys to get it starting.
                    The problem is, that the micom Version doesn't match with the bios version, see picture.
                    How can i update the Micom Version? The Samsung bios update wont work.
                    With https://github.com/tavinus/SamsungBIOSTools i could extract the newest bios update...
                    01-09-2025, 01:35 PM
