hp 655 newton_br_hpc bios
+ More Options
Posts
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    hello
    does someone happen to have bios dump for amd
    hp 655
    pn: 010172W00-600-G
    NEWTON_BR_HPC
    MV_MB_V1
    it turns on, blink 3 times, pause, blink 4 times and turn off
    3 times blink = ram, but i tried 3 modules, all same
    4 times blink = vga, reflowed but no change (apu vga, cpu soldered)
    tnx in advanced
    here is my not woking dump
    Im Back... sort of...
  • Djosla
    • Dec 2012
    • 246
    • Montenegro
    Re: hp 655 newton_br_hpc bios
    That can be bad apu cpu,that ting has tendency to fail...
    here is your dump...
    ah sad vidim brat bosanac...
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      thank you very much...
      i found two more dumps but no go
      in between testing laptop died completely
      giving up on this one...
      @Djosla
      aha brat bosanac se bori sa elektronikom
      ljep pozdrav za CG
      • techman1025
        • Jun 2014
        • 497
        Hi
        Dead GPU heat it to confirm 150c older model always N/B
        Then a must to replace because it will fail again.
        Techman1025
        • rtstorm
          • Feb 2012
          • 971
          • Croatia
          Hello i have the same Hp 655 and no display. I try reflow gpu/apu but no help. I can hear that laptop start windows but no display show. Is this need to replace apu/gpu or something else?
          ...the quieter you become the more you are able to hear...
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            try another display, back light may be bad or lcd cable
            • rtstorm
              • Feb 2012
              • 971
              • Croatia
              i just check HDMI and it work, but no display on LCD. I will try to check lcd and cable
              • rtstorm
                • Feb 2012
                • 971
                • Croatia
                well i try with another lcd but same thing, can you advise what it coud be?
                • rtstorm
                  • Feb 2012
                  • 971
                  • Croatia
                  i check the LCD cable but i only get 19V, no other voltages on cable. Is this GPU fail?
                  • reset1986
                    • Dec 2014
                    • 308
                    • italia
                    HP 655 AMD bios dump 4MB
                    hi all are looking for a dump bios for hp 655 4 mb, on the site hp is 4.37MB and I do not know how to work it,
                    The machine sometimes turns on but does not show, sometimes it turns on for 3 seconds and goes off,
                    I wanted to flash the bios but I can not find it correct.
                    this is the corrupt dump done on the failed machine
                    Thanks to who helps me
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Re: HP 655 AMD bios dump 4MB
                      Try this and report
                      • reset1986
                        • Dec 2014
                        • 308
                        • italia
                        Try this and report
                        thanks, the file is from 4.37mb,
                        the backup is 4mb and is different
                        I have to change the file from 4.37 but I do not know how to do it
                        can you help me?
                        • imranromi
                          • Jan 2015
                          • 1288
                          • Pakistan
                          can you help me?
                          Is better to send board code i try.
                          • reset1986
                            • Dec 2014
                            • 308
                            • italia
                            P/N 010172W00-36V-G
                            Newton_br_hpc mv_mb_v1
                            thanks
                            • imranromi
                              • Jan 2015
                              • 1288
                              • Pakistan
                              P/N 010172W00-36V-G
                              thanks
                              Try here.
                              • reset1986
                                • Dec 2014
                                • 308
                                • italia
                                Try here.
                                thanks
                                I try to flas the bios, update after the post
                                • reset1986
                                  • Dec 2014
                                  • 308
                                  • italia
                                  I programmed the bios, the notebook always does the same problem,
                                  I'm reballing the AMD chipset
                                  I see if I can make it work
                                  • reset1986
                                    • Dec 2014
                                    • 308
                                    • italia
                                    hi friends, I update the post saying that I reballed successfully on the amd chipset, the pc now works perfectly, the problem resided in the chipset, thanks to all for the support
                                    • tysovyc
                                      • Mar 2017
                                      • 11
                                      • zimbabwe
                                      Originally posted by ala_borbe
                                      hello
                                      hp 655
                                      pn: 010172W00-600-G
                                      NEWTON_BR_HPC
                                      MV_MB_V1
                                      tnx in advanced
                                      this bios work perfect it might be your gpu tested it
                                      • tysovyc
                                        • Mar 2017
                                        • 11
                                        • zimbabwe
                                        hello
                                        hp 655
                                        pn: 010172W00-600-G
                                        NEWTON_BR_HPC
                                        MV_MB_V1
                                        tnx in advanced
                                        check fbs11 and fbs7 for gpu power if power is ok then replace gpu or reflow
                                        • macabook
                                          πŸ› οΈ MSI GP75 Leopard MS-17E71 – No Display, Deep BIOS/EC Troubleshooting
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
