8mb bios file is too long for 8mb chip?
  • bjhawfam
    • Dec 2014
    • 144
    I decided to start a new thread, in hopes there are folks more knowledgeable than I. I searched high and low until I found a bios file that I needed, eventually I prevailed. I tried to program the chip and received the error message "file is to long"!!! Interestingly, I have tried several bios files that were 8mb in length ON THE SAME CHIP with no error messages. I'm guessing the bios file MUST have a tiny useless file within, correct? When I check the size of a different Samsung 8mb bios file that lets me program the chip, it's the same size as the 8mb Samsung bios file that returns an error. So basically we must be talking about a few kb difference correct?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: 8mb bios file is too long for 8mb chip?
    Attach the BIOS file here and we'll take a look. Some BIOS files have some extra info appended at the end for the manufacturers' BIOS update tools to use. This info prevents, for instance, flashing it on the wrong system. Sometimes it is also responsible for detecting whether the battery is charged or the AC adapter is plugged in, sometimes they use a separate utility for that.
    This kind of BIOS file is very common with Dell for example, or other laptops that use Phoenix BIOS (.WPH files). Most of the time it's a simple job of trimming the end of the file so it fits exactly into your BIOS chip.
    A working TV? How boring!
    • bjhawfam
      • Dec 2014
      • 144
      Thanks in advance, here's the file..
      • bjhawfam
        • Dec 2014
        • 144
        Well, guess not it claims it's an invalid file...One sec I'll figure this mess out.
        • bjhawfam
          • Dec 2014
          • 144
          Let's try this! changed it to an .rar file.
          • bjhawfam
            • Dec 2014
            • 144
            Thanks for all the help I solved the problem I just needed to re download the file
            • pravinj
              • Oct 2016
              • malaysia
              Iam new to this site,but found interesting discussion and solutions.So,here is my issues Iam trying to flash my BIOS chip W25X80VSIG.I have EZP2010 programmer but BIOS file i downloaded from Fuji Siemens website(laptop model Esprimo Mobile 9400) it's say too long(file Size 1027 KB).Can i get help how to troubleshoot this issue.I have read some thread which discuss on this. kindly help.Thanks
              • crozoki
                • Feb 2013
                • 44
                • Croatia
                Hi!
                I have problem here on Hp G6 1125sm. I download bios file from hp support in exe file and then unpack bios. when i took file from unpacked bios with ezp 2010 its say"file is to big"
                any advice
                  • 31260
                  upload the extracted file.
                  • crozoki
                    • Feb 2013
                    • 44
                    • Croatia
                    board is DAOR22MB6D1 R22
                    • DynaxSC
                      ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                      by DynaxSC
                      Hi
                      I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                      08-04-2025, 12:20 PM
                    • testaccgta
                      Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
                      by testaccgta
                      Hi, everyone!
                      I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
                      I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
                      09-01-2024, 08:24 PM
                    • traxformania
                      TONGFANG "GM7TG7P" Bios Password Problem?
                      by traxformania
                      I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                      But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                      I'm trying to reset my bios without success.
                      I tried :
                      -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                      11-15-2023, 07:32 AM
                    • JoWed
                      Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                      by JoWed
                      Hello Community,
                      I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                      07-01-2025, 09:32 AM
                    • Citymin
                      by Citymin
                      S/N : 5RNK9FFT70...
                      08-05-2025, 05:12 AM
