Looking for a bios dump for an old Gateway MD2614U, I believe the board is a Foxconn DA0AJ6MB6E0. Thanks
Bios dump for Gateway MD2614U
Tags: None
Re: Bios dump for Gateway MD2614U
backup ypur old bios first
http://us.gateway.com/gw/en/US/conte...vers-downloads
select: Notebooks>MD Series>MD26>BIOS
download and extract with winrar or so, there will be raw bios file
chack first is that exact model of your laptop
then upgrade to desired version incrementallyIm Back... sort of... -
then upgrade to desired version incrementallyComment
by AhariHi all,
I...-
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM - Loading...
