Toshiba Satallite L850-1RF PSKG8E Bios dump
  • teknikbursa
    • Sep 2014
    • 64
    • turkey
    I need Toshiba Satallite L850-1RF PSKG8E - 02Y00DTE Bios dump
    Mainboard PFL/CSF 45W UMA & DSC MB REV.2.1
  • teknikbursa
    • Sep 2014
    • 64
    • turkey
    Re: Toshiba Satallite L850-1RF PSKG8E Bios dump
    any one help
    • highpulse
      i hate HP
      • May 2013
      • 1490
      • portugal
      hum the uma i think i can give you hold on let me chek if this board is compatible with yours
      • highpulse
        i hate HP
        • May 2013
        • 1490
        • portugal
        rty does 2 mate , but first the main one
        • khaahk
          • Dec 2013
          • 812
          • Estonia
          Another to try - from toshiba website
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            by looking at your dumps, it should be F8 model
            here is main+ec from toshiba support site
            try it if you will, hope it works
            Im Back... sort of...
            • teknikbursa
              • Sep 2014
              • 64
              • turkey
              thank you my friend
              • teknikbursa
                • Sep 2014
                • 64
                • turkey
                Thank you wery much
                • teknikbursa
                  • Sep 2014
                  • 64
                  • turkey
                  Thank You Will try on monday
                  • kiyanmz
                    • Dec 2015
                    • iran
                    which one was "OK" my freind?
                    • Browning55
                      • Mar 2015
                      • 28
                      • turkey
                      Need L850-1RH dump bios +Ec
                      • kadi144
                        • Aug 2015
                        • 690
                        • algerie
                        Toshiba satellite L850-1Z1 bios
                        hi
                        i need a Toshiba satellite L850-1Z1 bios
                        PART NO : PSKG8E
                        Merci
                        • kadi144
                          • Aug 2015
                          • 690
                          • algerie
                          Re: Toshiba satellite L850-1Z1 bios
                          Hi!!!!!!!!!!!!!!!!!
                          • crowntoy99
                            • Oct 2012
                            • 267
                            • india
                            try this
                            • Andyservo
                              • Jun 2013
                              • 152
                              • Indonesia
                              thanks mate...i will try...
                              • ufuksert
                                • Aug 2014
                                • yuorgn
                                toshiba l855-14p
                                • kadi144
                                  • Aug 2015
                                  • 690
                                  • algerie
                                  bios TOSHIBA L850-1JG PSKG8E coreI7
                                  hi
                                  i need help for the bios
                                  PLF/CSF 45W UMA DSC MB
                                  REV: 2.1
                                  MERCI
                                    • 21907
                                    Re: bios TOSHIBA L850-1JG PSKG8E coreI7
                                    Try this one: https://drive.google.com/file/d/0B6I...ew?usp=sharing
                                    • kadi144
                                      • Aug 2015
                                      • 690
                                      • algerie
                                      THANKS
                                      lader not working
                                      the PART NO : PSKG8E
                                      there are two bios
                                      ec=2m
                                      main =4m
                                      i need this bios ......pls
                                        • 21907
                                        Here you go,try this bios 2MB + 4MB ,flash both .
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • mkdj
                                          by mkdj
                                          Dear all,
                                          10-19-2025, 04:41 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          💀 Problem:😅
                                          08-07-2025, 04:54 AM
                                        • DProf.
                                          TOSHIBA DYNABOOK T55/AB, PT55ABP-BJA2 BIOS DUMP
                                          by DProf.
                                          High great minds, please i need bios dump for this system .or help to REMOVE the PASSWORD in my original dump
                                          Toshiba Dynabook T55/AB, PT55ABP-BJA2
                                          MODEL NAME. Satellite L50-D series
                                          P[ART NO PS57MN-00600R
                                          Attached is my original bios dump ADMIN. PASSWORD LOCKED. Thank you in advance....
                                          09-26-2024, 04:30 AM
