HP Sleekbook 15-B121EL
  • longislandtea
    • Sep 2014
    • 41
    • Italia
    Hi guys, I have EZP2010 bios programmer.
    I took from HP Sleekbook 15-B121EL MB bios chip and read to programmer.
    I took a file 4.194.304 byte size. I want to reprogram chip but new bios from hp support has 4.589.312 byte size and when I try to programming chip get error "file is too long".
    How can I fix nex file so I can program bios?
    PLEASE HELP HOW CAN I FIX NEW FILE SO I CAN REPROGRAM BIOS.
    HERE IS ORIGINAL FILE FROM MB
    Inside rar file I put the original bios and 2 file that I found into HP support archive.
    Please give me guideline to fix this common issu in hp laptop or simply help me!!!
  • dycc
    Vision
    • Nov 2011
    • 625
    • Côte d'Ivoire
    Re: HP Sleekbook 15-B121EL
    GIVE MOBO CODE SOMETHING LIKE daou56mb6e0
    • longislandtea
      • Sep 2014
      • 41
      • Italia
      DA0U56MB6E0 Rev: E
      • dj_ricoh
        • 2073
        the original file must be the same If its to big then its not the same.
        you try to write another bios that its not for your motherboard
        • longislandtea
          • Sep 2014
          • 41
          • Italia
          I think that the bios downloaded from hp support was coded and must be decrypted or removed some parts
          • dj_ricoh
            • 2073
            no
            every time I go on the website and I get the exact file.
            only if I try to put another goes bad and say file to big
            • longislandtea
              • Sep 2014
              • 41
              • Italia
              Ok. I'm disagree with you.
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                two working dumps
                Im Back... sort of...
                • djharold
                  • Aug 2015
                  • 245
                  • COLOMBIA
                  thanks a lot
                  • Citymin
                    by Citymin
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
                  • m1ch43lzm
                    Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                    by m1ch43lzm
                    Hi everyone
                    I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                    Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                    Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                    There's also an extra OTP Secu.R...
                    09-06-2025, 05:47 PM
                  • Forest79
                    by Forest79
                    However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                    07-23-2023, 07:39 AM
                  • maanee11
                    Help to get Lenovo BIOS bin file for Thinkpad T560
                    by maanee11
                    Hello Everyone,
                    I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                    https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                    In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                    05-15-2022, 11:59 AM
                  • Sebastian Codrean
                    BIOS file for ASUS F542UN laptop
                    by Sebastian Codrean
                    Hello to all of you! I need help with a BIOS file.
                    The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                    So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                    02-20-2025, 10:25 AM
