Dell XPS 13 9345 bios needed
  • regged
    • Sep 2014
    • 29
    • Yem
    Hi. Who has 64MB bios dump for Dell XPS 13 9345 with snapdragon cpu?
    • 21880
    Type the laptop service tag, full name and model, motherboard model, etc.
    post the contents of the bios chip even if it is corrupted..
    read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
    • regged
      • Sep 2014
      • 29
      • Yem
      Dell XPS 13 9345
      Service Tag: 4T53D44
      • minhdigital
        • Nov 2022
        • 765
        • Vietnam
        Dell XPS 13 9345
        Send to you, try !!
        • zenius
          by zenius
          12-08-2024, 06:13 AM
        • mikeybass
          by mikeybass
          04-23-2025, 04:30 PM
        • capoplays
          Help with BIOS update on Dell G15 5515 after chip replacement
          by capoplays
          Hey everyone,
          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
          When I check the BIOS using the F12 menu Flash...
          10-24-2025, 06:53 AM
        • Akhlz001
          by Akhlz001
          09-20-2025, 07:15 PM
        • 417731
          BIOS needed for Dell Vostro 3405
          by 417731
          Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
          Model: Dell Vostro 3405
          Tag:F0B1YF3
          CPU:Ryzen 3500U
          Thanks in advance
          07-06-2025, 06:48 PM
