Vertyanov_JIG_ver_7.9 firmware
  • emaghanim
    • Dec 2014
    • 134
    • egypt
    pls any one have Vertyanov_JIG_ver_7.9 software can share it
    thanks
  • rediii
    h???, spurrrn
    • Mar 2018
    • 504
    • somewhere in europe
    thanks
    i just can share this:
    • emaghanim
      • Dec 2014
      • 134
      • egypt
      This link is for ver 8.1
      i need older version 7.9
      if any one have it
      thanksClick image for larger version
      • DarrenHD
        Firmware for older Toshiba TV 22CV100U
        by DarrenHD
        HI all, Does anyone know if there exists an archive for older firmwares for Toshiba TV's? I've searched all over Toshiba's various websites and also on Dynabook's site (they say they deleted all old firmwares due to "server space". ) Toshiba has not replied to my request.
        I'm looking for Firmware 1.07 for the 19/22/26/32 C100U series as described in this link:
        https://support.dynabook.com/support...tentId=2865076
        Thanks!
        06-16-2025, 11:56 AM
      • Venniiee
        Memory software for older gpu's
        by Venniiee
        Hello everyone ,
        Im a beginner in repairing gpu's and ofcourse i start with low and cheap cards to repair before jumping to the big boys .
        I have seen the popular post of "software for gpu memory problems" with the grub menu and everything , and i am using it .
        Currently i am working on gtx 500 & 400 series cards , like the 560 & 460 for example .
        The program should work with 500 series , but i cant get it to run on my gtx 560 . Any suggestions ?
        Also the "ms-dos" option in the menu , how to work that ? I cant find...
        11-13-2022, 12:26 PM
      • zklgfs
        Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
        by zklgfs
        I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
        08-11-2025, 02:14 PM
      • gurj1979
        Ubiquiti firmware help. US-8-150W POE
        by gurj1979
        Hi guys.
        I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
        Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
        So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
        Got New chip and writes good.
        THE PROBLEM...
        It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
        Does anyone have a Good Firmware I can have?...
        07-22-2024, 05:13 PM
      • janos6662000
        Philips 47PFS7509/12 LCD TV problem
        by janos6662000
        Hi
        I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
        When i applied cable signal to check image, i had normal picture, but TV was restarting.
        I downloaded original firmware and applied the update, but the problem remained.
        From a colleague i received a "factory package software" which is a lot bigger.
        I made another firmware update, but still did not solve the problem.
        Somewhere on the way the error got worse, because at the moment the...
        08-12-2025, 12:54 PM
