17n_amd_fp6_lucienne bios
  • orochimarik
    Mark
    • Nov 2024
    • 10
    • Україна
    I'm posting in this thread because I have a very similar model and I'm not able to create a new topic yet.
    Laptop Model: HP 17-cp0003sf Motherboard: 17n_amd_fp6_lucienne
    SN 5CG42005KK
    Problem: The laptop is stuck in a boot loop and will not start.
    Symptom sequence:
    1. On the first power-on, a recovery screen appears with a progress bar.
    2. The process finishes or fails, and the laptop shuts down.
    3. It automatically powers on again to a black screen and hangs (no POST).
    I am looking for a working BIOS dump for this model. I have tried to build one from the official updater, but the firmware is packed inside the EXE in a complex way that I cannot extract.
    I am attaching my two files:
    1. My original 16MB backup. The file is structurally corrupt (UEFITool can't parse its regions), but it should contain the board's original DMI information (Serial Number, MAC address, etc.).
    2. The official BIOS update EXE from the HP support site.
    Could someone please help me by either extracting the firmware from the EXE or providing a known-good dump with my DMI data transferred?
    Thank you very much.
    • 22279
    Post moved to a new thread. How old is your UEFITool, are you using the latest one .
    • orochimarik
      Mark
      • Nov 2024
      • 10
      • Україна
      Originally posted by SMDFlea
      Повідомлення перенесено в нову тему. Скільки років вашому UEFITool, чи використовуєте ви найновішу версію.
      Я використовую найновішу версію UEFITool
      .I'm using the latest version of UEFITool
      in English please..
      • m1ch43lzm
        • Mar 2019
        • 1126
        • Peru
        Just run the .exe in another PC, you'll get 3 options, first to update BIOS (won't work unless it's the same model), second to create USB recovery drive, and the third Advanced option, which will extract the BIOS
        If your PC crashes when running that .exe, try on a VM or another PC
        You'll get 2 .bin files, the correct one is 088C6.bin
        Use this guide written by Vesko356
        https://www.badcaps.net/forum/troubl...-file?t=121948
        and https://www.badcaps.net/forum/troubl...flash?t=122195
        Code:
        FfsParser::checkTeImageBase: TE image base is neither zero, nor original, nor adjusted, nor top-swapped
        I get the same error on the clean BIOS extracted from HP, it's normal, even on a working BIOS
        Try, clean BIOS extracted from HP website, serial/win key inserted
        HP Laptop 17-cp0003sf (9D5S2EA)
        BID 088C6
        BIOS ver F.30
        S/N 5CG42005KK
        DMI 413000-41403F
        Win key 435000-43503F
        • orochimarik
          Mark
          • Nov 2024
          • 10
          • Україна
          Code:
          BID 088C6
          BIOS ver F.30
          S/N 5CG42005KK
          DMI 413000-41403F
          "Thanks a lot, everything's working perfectly!
          • cr4zychriss
            by cr4zychriss
            • Rebrand: PC Specialist
            11-14-2025, 04:04 PM
          • istvanszasz99
            Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
            by istvanszasz99
            Product Name: Razer Blade 15 (2022)
            Product ID: RZ09-0421
            Motherboard: CH580
            BIOS Versions I work with: 2.02 & 2.06
            Bios File Size: 32,768 KB
            Dear Forum Readers!
            I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
            I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
            The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
            !!! MY RAZER BLADE...
            11-24-2025, 05:52 PM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • Wahaz
            by Wahaz
            10-30-2023, 08:42 PM
          • Bloodhoundje
            HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
            by Bloodhoundje
            I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
            I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
            After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
            I have desoldered the bios chip (GigaDevice...
            03-16-2024, 03:12 PM
