Vostro 15 (5000 Series) S\N -E7A8 Locked bios
  • Matff4
    • Sep 2025
    • 3
    • Poland
    Hi, I have locked Vostro and Im trying to clear password flag from the bios dump but cant find anything closely related to what Im looking for in both vss stores (extracted via UEFI Tool).
    Could someone point to an offset or region where I should look to remove password lock?
    Thanks in advance
  • m1ch43lzm
    • Mar 2019
    • 1021
    • Peru
    https://www.badcaps.net/forum/troubl...23#post1622423
    3.4. Dell
    Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
    See: https://beta.bios-pw.org/ .If the website is offline try: https://web.archive.org/web/*/https://bios-pw.org/
    Note: All passwords must be entered with a US QWERTY Keyboard,you can use a USB one.
    Note: The 6FF1 suffix has a bug,use your service tag with the 1F5A or BF97 suffix instead,Example: 1234ABC-BF97 .
    Note: The list of examples does not include some other suffix codes that do work,such as E7A8 .
    Note: If the BF97 suffix does not work try it with the E7A8 suffix instead.
    Note: There is no publicly available 8FC8 generator available at the moment.
    The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
    8FC8 Patcher software: https://www.badcaps.net/forum/troubl...l-8fc8-patcher
    • Matff4
      • Sep 2025
      • 3
      • Poland
      Ive tried using https://beta.bios-pw.org/ in the first place, but none given passwords worked.
      EDIT:
      It worked when pressed CTRL+ENTER after typing password
      • macabook
        by macabook
        🧩 Initial Issue
        07-24-2025, 02:17 PM
      • pirati
        by pirati
        10-27-2025, 04:20 PM
      • kuraimangetsu
        DELL VOSTRO LA-L246P BIOS LOCKED NEED TO UNLOCK
        by kuraimangetsu
        Hi guys
        i have this laptop with locked bios!
        tried to flash it with some bins i found but with no vail. either no boot up at all or boots to green blue red screens only!
        tried to download latest bios from dell site and exctracted bin files from exe bios but got no boot at all after flashing that
        here is the dumbs for both chips 16 and 8
        12-24-2023, 05:04 AM
      • 417731
        BIOS needed for Dell Vostro 3405
        by 417731
        Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
        Model: Dell Vostro 3405
        Tag:F0B1YF3
        CPU:Ryzen 3500U
        Thanks in advance
        07-06-2025, 06:48 PM
      • Vesko356
        by Vesko356
        08-11-2023, 03:27 AM
