hp laptop LA-L311p bios required
  • jesi
    • Jul 2013
    • 78
    • uk
    hp laptop
    14-ef2502na
    CND34117S8
    LA-L311P motherboard
    require bios please , i have attached bios which i downloaded from hp support website , is it possilbe to extract bios and the ec from it
    i dont know how to do it , trying for the past 12 days but no joy
    would be appriciated
    thankyou in advance to all techs
  • m1ch43lzm
    • Mar 2019
    • 942
    • Peru
    [Guide] How to extract ready for programming dump from HP update executable file
    and
    HP consumer laptops are one of the easiest to get a clean BIOS from BIOS update
    Make a backup of the corrupted BIOS first and post it here, it's needed to extract serial number/product ID/feature byte/Win key, and in some models when the BIOS update has several files, to find the right BIOS version
    For the EC, please share the EC model (ITE, ENE, ....), someone will try to extract from main BIOS
    I'll attach the extracted BIOS from version F.08 (previous version) sp158840.exe
    HP Spectre x360 2-in-1 Laptop 14-ef2502na (7Y8Y3EA)
    BID 08BA0
    Bios ver F.08
    Clean BIOS, no DMI, no Win key, I don't know the right offsets to insert that info (need original/corrupted BIOS backup for it)
    • Bloodhoundje
      by Bloodhoundje
      03-16-2024, 03:12 PM
    • JoWed
      Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
      by JoWed
      Hello Community,
      I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
      07-01-2025, 09:32 AM
    • thxd43
      Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
      by thxd43
      Hello, first of all, excuse me, I am using the translator, English is not my native language.
      I have a Lenovo ideapad 330S - 14IKB laptop.
      The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
      02-23-2023, 08:37 PM
    • legendkray
      BIOS Help Regarding GM5IX7A-GM6IX7A Origin Laptop
      by legendkray
      I have OriginPC EON 15SL, however, my laptop starts and shutsdown after 1-2 second. Keyboard leds are coming on then fans spinning then it shutsdown and not turning back on unless I plug out the power cable and plug it in. I had issues with bricked BIOS then I flashed BIOS I got from the vendor to the SPI chip and still it didn’t worked because my EC firmware was newer than the BIOS I have flashed. So I wanted to try flashing the EC chip with the correct firmware that matches with the BIOS also from the vendor and it worked everything was well, and then stupid me wanted to unlock some...
      07-05-2025, 09:25 AM
    • AquaMan Ua
      Problem with PANASONIC CF53 laptop after changing BIOS settings
      by AquaMan Ua
      Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
      05-17-2025, 09:40 AM
