Acer AL14-31P-C8KV BIOS Request
  • justice171
    • Feb 2018
    • 110
    • South Africa
    Hello Badcaps Team,
    I am working on an Acer AL14-31P-C8KV laptop (S/N: NXKS8EA0013490A9C74500) with board number T140AN Rev 3.0A.
    I received this unit for repair, but I am uncertain if the current BIOS is correct. There are clear signs of previous work – I noticed flux residue around the BIOS chip, which suggests the BIOS may have been tampered with or reprogrammed before. Because of this, I am not confident that the backup BIN I have is the original dump or if it belongs to this exact machine.
    Could you please assist me with:
    • A clean BIOS BIN for this model, or
    • A new/repaired BIN cleaned from my dump (if possible).
    Attached is the backup. Any help would be greatly appreciated.
    Thank you in advance for your support!
    Best regards,
  • imraycooper
    • 16
    • south africa
    hello badcaps team
    i also need help with bios for t140an rev3.0a
    laptop came witho no bios chip at all but charging light is goin on
    i attach detailed images of the laptop s/n
    thank you all again
      • 22276
      Originally posted by imraycooper
      hello badcaps team
      thank you all again
      Type and post the S/N Service Tag or SNID, full name and model, motherboard model, backup etc. Don`t post pictures of the serial number...
      read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
      • imraycooper
        • 16
        • south africa
        hello badcaps team
        thank you all again
        acer aspire lite
        al14-31p-c8kv
        model no n23g1
        sn. nxks8ea00142201e4c4500
        snid-42200775645
          • 22276
          Originally posted by justice171
          Hello Badcaps Team,
          hello badcaps team
          Attached is a virgin bios with the DMI from the backup at post #1 .Just change the serial number to your own using a hex editor. The S/N is NXKS8AL00234902E3F4500
          • imraycooper
            • 16
            • south africa
            hello badcaps team
            i reprogrammed my acer using neo programmer with the above biin file
            however i still have only power led and the fan spinning continuously
            all voltages are ok
            any ideas pliz or im still stuck with my bios issue??
            • jomaseko
              • Nov 2022
              • south africa
              download another bin file
              • istvanszasz99
                Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                by istvanszasz99
                Product Name: Razer Blade 15 (2022)
                Product ID: RZ09-0421
                Motherboard: CH580
                BIOS Versions I work with: 2.02 & 2.06
                Bios File Size: 32,768 KB
                Dear Forum Readers!
                I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                !!! MY RAZER BLADE...
                11-24-2025, 05:52 PM
              • Wg188
                ACER Veriton Z4660G AIO bios help
                by Wg188
                I have an Acer veriton Z4660G all in one pc,
                Model: Z4660G-I5850H1 (VZ4660G_W)
                Need bios dump and schematic would save my life !
                to make a long story short I bought this all in one used
                with a broken lcd, with the objective of making a custom desktop out of it
                ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
                06-17-2023, 02:20 PM
              • zenius
                by zenius
                12-08-2024, 06:13 AM
              • Wahaz
                by Wahaz
                10-30-2023, 08:42 PM
              • hotcrossedbuns999
                M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                by hotcrossedbuns999
                My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                3. I could only locate two chips that look like bios chips. Could someone verify this
                01-03-2025, 12:32 PM
